Speed, Velocity, Acceleration, etc. at t=0
2 replies · 1K views · last reply
logan3
I was wondering how speed, velocity, acceleration and anything with a [itex]\Delta t[/itex] in the denominator are defined at [itex]\Delta t=0[/itex]? Other than approximating with limits, aren't they undefined?
Ex: [itex]{\vec{v_{avg}} = \frac{\vec{s}}{\Delta t}}[/itex], at t = 0 [itex]\Rightarrow {\vec{v_{avg}} = \frac{\vec{s}}{0}} \Rightarrow {\vec{v_{avg}}} = und.[/itex]
[itex]{\vec{a}} = \frac{\vec{v_{f}}-\vec{v_{i}}}{\Delta t}[/itex], at t = 0 [itex]\Rightarrow {\vec{a}} = \frac{\vec{v_{f}}-\vec{v_{i}}}{0} \Rightarrow {\vec{a}} = und.[/itex]
Thank-you
Well as mfb pointed out, they are defined by derivatives, and thus they are instantaneous and not average.
There is no average velocity/acceleration defined at a given time t=0, but in some interval Δt. So your formulas are wrong...
For [itex]\Delta t \rightarrow 0[/itex] you have:
[itex]a(t_0)= lim_{\Delta t \rightarrow 0} \frac{ u(t_{0}+ \Delta t) - u(t_{0})}{\Delta t}[/itex]
You can expand the [itex]u(t_{0}+ \Delta t)[/itex] around t0:
[itex]u(t_{0}+ \Delta t) \approx u(t_{0})+ \Delta t \frac{du(t)}{dt}|_{t=t_{0}}[/itex]
(you could try to write more terms in the series so avoid the approximation symbol, but later on you are going to take the limit of [itex]\Delta t \rightarrow 0[/itex] and so you see only the first power would survive-the rest would have [itex]\frac{(\Delta t)^{2}}{\Delta t} \rightarrow 0[/itex] in that limit).
thus:
[itex]a(t_0)= lim_{\Delta t \rightarrow 0} \frac{ u(t_{0})+ \Delta t \frac{du(t)}{dt}|_{t=t_{0}} - u(t_{0})}{\Delta t}=\frac{du(t)}{dt}|_{t=t_{0}}[/itex]
As for a the acceleration (rate of change of velocity), a similar way is used for u, but with x instead of u (since it's the rate of change of position)
But there is no distinction between derivatives and limits... derivatives are mathematically defined by the first limit I wrote...now if you prefer listening to the name "derivative" instead of "limit" it's up to you. But all derivative properties are proved by their definition as limits.
