Speed with constant acceleration
The discussion centers on the confusion surrounding the formula v^2 = v0^2 + 2a(x - x0), which describes speed in the context of uniformly accelerated motion. It clarifies that v^2 represents the square of speed, while speed itself is the square root of this value. Participants note that the formula is more about the relationship between variables rather than solely calculating speed. The preference for using v^2 over the square root for simplicity is also mentioned. Overall, the conversation highlights the importance of understanding the context of the equations in physics.
ahuebel
Using a Newton equation for position and substituting (v-v0)/a for t you can get the following formula:
v^2= v0^2+2a(x-x0) where v^2 is supposedly speed. I understood speed to be tha magnitude of velocity which is the sqrt of the sum of the squares of the components (i.e. sqrt(vx^2+vy^2+vz^2)). I seem to be missing something... how is speed then v^2? I am sure it is right in front of my face but I am just not seeing it.
TIA
v^2 is the speed squared; v is the speed.
Realize that your formula ,v^2= v0^2+2a(x-x0), is for uniformly accelerated straight-line motion.
Thank you. It just seems odd that if they would state that an equation is speed as a fucnction of position it would be much better to have that equation be v = sqrt(v0^2+2a(x-x0)). It can throw simple people like me off :).
Think of that equation as a relationship among all the different variables, not just as a formula for finding speed. Depending upon what information is given, you may wish to use it to solve for any of the variables. (And having a single v^2 is much nicer looking than that ugly square root! :smile: )
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 49 ·
