Tomax911
- 3
- 0
Gents,
I am looking for a design modification to accomplish 250,000 cycles of pressure loading in a short time period. We are going from 0 (1atm) to 10psi but currently only getting 10 cycles in 120 seconds. Enclosed is a diagram of the system.
Details:
The theory is that the rate of pressurization is much too slow due to the small diameter input lines. What should the correct configuration be? Some ideas if we keep the same power source is to increase the line size (to what?) and to employ a pressure tank very close to the system to enable large (fire hose size?) input lines. If that is the case adequate control will also be and issue. 3hz will require just 0.16 seconds for each stroke of compression or tension on the actuator 2 rod with transition (turn around) time going to zero. Other ideas include using and electric motor with some sort of cam system to create the correct pressure over that number of cycles.
So in a nutshell. . .
What is the physics solution behind the problem?
What is the optimal and most economical setup to get the testing done?
V/R
Tomax
Details:
- Rate goal is 3hz
- Power Source is air at 120 psi
- Pressure Vessel is 4.75 cubic ft
- Fluid inside the pressure vessel is 75% antifreeze and 25% water
- Actuator1 is 1quart size and filled with air
- Actuator2 is 2 quarts in size and filled with water
- Actuator1 is linked to actuator2 with a steel ram
- Actuator2 is linked to the pressure vessel with a 0.25in (6.3mm) hose
- The control system box has a 120psi inlet and a 1/2" air hose
- Actuator1 has two 1/4" inlet/outlet lines
- Actuator1 can pressurize either side of its diaphram through the 2 lines face
- Actuator2 has an open side of the diaphram and a fluid side
V/R
Tomax
