Sphere has the minimum surface area?
The discussion centers on proving that a sphere has the minimum surface area for a given volume, a concept rooted in the isoperimetric inequality in three dimensions. The participants explore the variational problem using the Euler-Lagrange equation, specifically focusing on the surface of revolution defined by the function y(x) between -1 and 1. Key equations include the surface area S and volume V expressed through integrals. The conversation highlights the complexity of the proof, emphasizing the need for a deeper understanding of Calculus of Variations and differential equations.
  • Understanding of the isoperimetric inequality in three dimensions
  • Familiarity with Calculus of Variations
  • Knowledge of Euler-Lagrange equations
  • Basic skills in solving differential equations
  • Study the isoperimetric inequality proofs available at Cornell Math and Stanford University
  • Learn about the Euler-Lagrange equation and its applications in variational problems
  • Explore advanced techniques in solving differential equations related to variational calculus
  • Review the principles of surface area and volume calculations for surfaces of revolution
Mathematicians, physics students, and anyone interested in advanced calculus, particularly those studying variational principles and geometric optimization.
persia7
How do you prove that for a given volume, sphere has the minimum surface area?
It is a standard problem in "Calculus of Variations" so you might also check that.
i tried to find proofs but i don't find please show me proofs
How about first doing it for a surface of revolution, say for y(x) between -1 and 1. Then the surface is:
S=2\pi \int_{-1}^1 \sqrt{1+(y')^2}dx
and the volume of this surface of revolution is:
V=\pi \int_{-1}^1 y^2 dx
via discs.
Now, in the language of variation, we wish to minimize S while keeping V constant. The Euler condition for this problem is:
\frac{\partial H}{\partial y}-\frac{d}{dx}\frac{\partial H}{\partial y'}=0
with
H=V+\lambda S
Now, I've never solved this particular variational problem before ok, but if it were mine, I'd first see if I can get a circle out of Euler's equation thus showing me that a sphere has the minimum surface area for a given volume.
via discs.
with
H=V+\lambda S
can you show me a proof in internet?
thanks to all
I worked with it a bit but ran into a DE I couldn't solve or else I had errors. But that's ok guys, don't tell me how to do it. I rag on others here about that: pretty soon you'll get to a problem that no one else on Earth can help you with and then you will have to go all by yourself so might as well get some practice. :)
Oh yeah, thanks guys for those references about isoperimetric inequality. All news to me. :)
Well, what do you expect? That is a very technical, difficult proof, involving, as I said before, "Calculus of Variations". Whole courses are taught on that subject! It isn't something you can expect to go over in an afternoon!
I really was expecting the variational problem I set up to fall right through. Spent about an hour on it yesterday. I'm missing something because a get a really messy DE but maybe my approach is not the easiest variational formulation to use. Still though if the DE I derived at is correct, then I should be able to back-substitute the equation for a circle and get equality but when I do that I do not get equality so I got a problem.
Dang it! I'm missin' a y:
S=2\pi \int_{-1}^1 y \sqrt{1+(y')^2}dx
I think I need to review some things first . . .
I get for the Euler equation:
1+(y')^2-yy''+\lambda y\left(1+(y')^2\right)^{3/2}=0
where \lambda is an arbitrary parameter.
Now, I'm going to cheat a little bit because I'm not good at this: I know the solution should be a circle, so when I substitute y(x)=\sqrt{1-x^2} into the left side of the DE above, in order for it to be zero, \lambda=-2. Therefore, we want to solve:
1+(y')^2-yy''-2y\left(1+(y')^2\right)^{3/2}=0
I started a thread in the DE forum because I needed help to solve it. It's here:
https://www.physicsforums.com/showthread.php?t=702671
Thanks to fzero and Jacquelin, we obtain:
\frac{dy}{dx}=\frac{\sqrt{y^2-(y^2-c_1)^2}}{y^2-c_1}
Now, just for the purpose of actually making progress with this problem albeit not the best way, I'm going to let c_1=0. Then we wish to solve:
\frac{dy}{dx}=\frac{\sqrt{1-y^2}}{y}
with the solution being:
y^2+(x+c_2)^2=1
Letting again c_2=0, we get the desired extremal: x^2+y^2=1.
All that remains to be done is to justify my particular values of the constants c_0, c_1,\lambda.
If someone can do this, I think we'd have a pretty decent proof of this theorem.
Also I forgot, this is only a necessary condition for a minimum. I think we would have to look into the second variation to prove this is a minimum.
