Spherical Mirror and Object Distance
  • Thread starter Thread starter Skye77
    Mirror Spherical
The discussion centers on determining the type of spherical mirror and the object's distance when an object is placed in front of it and magnified to twice its size. It is concluded that the mirror is concave, as convex mirrors reduce image size. The radius of curvature is given as 0.24 m, leading to a focal length of 0.12 m. The correct approach to find the object's distance involves using the mirror equation and magnification formula, ultimately leading to a positive object distance. The final consensus is that the object distance should be 0.12 m, correcting earlier mistakes in calculations.
Skye77
If a spherical mirror has a radius of curvature of .24 m and and object is placed in front of it and magnified to twice its size: is the mirror concave, convex, or either? And what is the object's distance?
I determined that the mirror was concave, because the question said that the image was twice the object's size and convex mirrors decrease image size. Is this correct?
I'm having trouble finding the object's distance too. I know that M = - di/do. And M will either = 2 or -2 because the image could be real or virtual.
From the question I got that R = .24 and since F = R/2, F = .12
Then, using the equation 1/do + 1/di = 1/F, I rearranged to get
do + di = F and since F = .12,
do = .12 - di
I solved for di using M = - di/do with M = 2, so
2 = - di/do rearraged to,
di = - 2do
Plugging this to the spherical-mirror equation gave me: do = .12 - (- 2do)
Solving gives: do = - .12 m
Is this correct? Am I going about this the right way, or am I way off base? Any help is appreciated. Thank you.
Yes.
do + di = F
This is wrong. Try again.
The object is in front of the mirror, its distance should be positive. But you are quite near to the right way :cool:.
ehild
So then am I only off because of the negative sign? So the answer would be .12 m
No, you made a mistake saying that di +do =F.
ehild
I got that equation from my book and I've tried rearranging it several times and I still get the same answer. What am I missing?
1/do + 1/di = 1/F
M= - di/do and since M = -2 I get di = 2do
Then I plug that into the equation and still get .12
di=M*do
1/do+1/(Mdo) =1/F
factor out do:
(1/do)*(1+1/M)=1/F
do=F*(1+1/M)
M is either 2 or -2., F=0.12 m.
Plug in.
ehild
Thanks for all the help. I just realized when I was doing my math I was making the same bone-head mistake over and over again.
Must get more sleep to avoid stupid mistakes!
  • · Replies 16 ·
