Spherical Trigonometry question
  • Context: Undergrad
  • Thread starter Thread starter dpatte
The discussion centers on solving a spherical trigonometry problem involving angles A, a, B, and b, with the goal of finding angles C and side c. The participants emphasize that, unlike plane trigonometry, spherical triangles require the use of the law of sines and the law of cosines to derive unknown values. Specifically, they outline the necessary formulas: the law of sines states that the sines of the sides are proportional to the sines of the opposite angles, while the law of cosines provides relationships between the sides and angles. The solution involves substituting and rearranging these equations to isolate and calculate the unknowns.
  • Understanding of spherical trigonometry concepts
  • Familiarity with the law of sines and law of cosines
  • Ability to manipulate trigonometric equations
  • Knowledge of inverse trigonometric functions
  • Study the law of sines in spherical triangles
  • Learn the law of cosines for spherical triangles
  • Practice solving spherical triangles with known angles and sides
  • Explore inverse trigonometric functions and their applications in solving for unknowns
Mathematicians, physics students, and professionals working with spherical geometry, particularly those involved in navigation, astronomy, and geodesy.
dpatte
Im trying to use spherical trig to solve a problem
In the standard method to compute the angles, I already have only the following four angles
A, a, B, b
but from these, how can I compute either C, or c?
Thanks
Mathematics news on Phys.org
welcome to pf!
hi dpatte! welcome to pf! :smile:
i don't think there's any simple way to do this
if it was plane trigonometry, C would be 180° - (A + B), but in spherical trigonometry i think all you can do is use the cosine rule and the sine rule and try to solve simultaneously for C and c :redface:
the sin rule says sin c/sin C = sin b/sin B = sin a/sin A. Since I don't have C or c, i don't see how I can use it.
the cosine rule says cos c = cos a cos b + sin a sin b sin C. Since I don't have c or C, I don't see how to use it either. :(
you have two unknowns (C and c), and two equations …
where's the difficulty? :wink:
A, a, B, b
Thanks
You actually have MORE information than you need to solve the triangle. Every spherical triangle has six parts (three sides, three vertex angles) each measured in degrees. Knowing any THREE parts, you can find any of the remaining three. There are three sets of formulas that let you do this (1) the law of sines (2) the law of cosines for sides and (3) the law of cosines for angles, stated below.
(1) In any spherical triangle, the sines of the sides are proportional to the sines of the opposite angles.
(2) In any spherical triangle, the cosine of any side is equal to the product of the cosines of the other two sides plus the product of the sines of those sides times the cosine of their included angle.
(3) In any spherical triangle, the cosine of any angle is equal to minus the product of the cosines of the other two angles plus the product of the sines of those angles times the cosine of their included side.
Suppose the vertex angles are labeled A, B, and C and the opposite sides are labeled a, b, and c. If you know two sides and one opposing angle or two angles and one opposing side, you would use the law of sines to find the unknown opposite the known. For example, if you were given angle A and sides a and b, you would find angle B by solving the equation
sin(A)/sin(a) = sin(B)/sin(b). Then we approach your question: if you know angles A and B and sides a and b, how do you find angle C and side c ?
from (2)
cos(c) = cos(a) * cos(b) + sin(a)*sin(b)*cos(C)
from (3)
cos(C) = - cos(A) * cos(B) + sin(A)*sin(B)*cos(c)
Use the last equation above, substitute the right hand side for cos(C) in the next to last equation above. Collect the terms that involve cos(c) on the left hand side of this equation, all other terms on the right hand side. Factor out and solve for cos(c). Taking the inverse cosine, you have the value for c. Use the law of sines for A,a, c, C to find the value for C.
If you'd like to see it worked out, let me know.
  • · Replies 81 ·
