Solving Ising Spin 1 Model w/ Transfer Matrix Method
The discussion focuses on solving the Ising Spin 1 Model using the Transfer Matrix Method. The transfer matrix is defined as T(i,i') with specific eigenvalues λ1 = 2 sinh(βJ) and λ2,3 derived from the matrix elements. The partition function Z is expressed as Z = λ1^N + λ2^N + λ3^N. The conversation highlights the need to correctly formulate the Hamiltonian and emphasizes that the 1D Ising model does not exhibit a phase transition due to rapid decay of spin correlations as temperature approaches zero.
  • Understanding of the Transfer Matrix Method in statistical mechanics
  • Familiarity with eigenvalues and eigenvectors in linear algebra
  • Knowledge of the Ising model and Hamiltonian formulation
  • Basic concepts of thermodynamics, particularly partition functions and phase transitions
  • Study the derivation of eigenvalues for the Transfer Matrix in statistical mechanics
  • Learn about the implications of Hamiltonian formulations in the context of the Ising model
  • Research the behavior of heat capacity near phase transitions in various spin systems
  • Explore the differences between 1D and higher-dimensional Ising models regarding phase transitions
Researchers and students in theoretical physics, particularly those focusing on statistical mechanics, condensed matter physics, and phase transition phenomena in spin systems.
Thales Castro
Consider the 1-domensional Ising model given by the Hamiltonian
H = -J \sum_{i=1}^{N} s_{i} s_{i+1}
where $s_{i} = -1, 0, 1$
Calculate the partition function $Z$ and the phase transition temperature.
Z = Tr(T^{n})
I did the first part using the transfer matrix method:
Z = Tr(T^{N})
In this case, the transfer matrix will be
T(i,i') =
\begin{pmatrix}
e^{\beta J} & 1 & e^{-\beta J}\\
1 &1 &1 \\
e^{-\beta J} & 1 & e^{\beta J}
\end{pmatrix}
To get the trace of $T^N$, you find the eigenvalues of T:
\lambda_{1} = 2 sinh(\beta J)
\lambda_{2,3} = \frac{1}{2} (2cosh(\beta J) + 1 +- \sqrt{ ( 2cosh^2(\beta J) + 2sinh^2(\beta J) )^2 - cosh(\beta J) + e^{-2\beta J} +9})
With this, the partition function is:
Z = \lambda_{1}^{N}+\lambda_{2}^N + \lambda_{3}^N
Now, to find the transition temperature, I'd have to find the zeros of the partition function or the singular points of the Helmholtz free energy, but I'm not quite sure on how to proceed from here. Any ideas? Thanks in advance.
If you can write a closed form expression for the partition function ##Z(T)## of a spin chain of ##N## spins, then the internal energy at temperature ##T## is, as described on this Wiki page:
##\displaystyle\langle E\rangle = -\frac{\partial\ln Z}{\partial\beta}##,
where ##\displaystyle\beta = \frac{1}{kT}## with ##k## the Boltzmann constant.
Then, when you know the internal energy as a function of temperature, you can divide it by ##N##, the number of spins, and take the limit ##N\rightarrow\infty## to find the internal energy per spin for the infinite chain of spins. If there is a phase transition at some temperature ##T_c##, then this internal energy per spin has a sudden "jump" at that temperature, or equivalently, the heat capacity ##C = d\langle E\rangle /dT## is infinite at ##T_c##.
In the case of finite but large ##N##, the heat capacity has a sharp peak at the approximate transition temperature, but not a real singular point.
First of all, your Hamiltonian is wrong. It should be$$\mathcal{H}=J\sum_{i=1}^N \sigma_{i} \sigma_{i+1} - H\sum_{i=1}^N \sigma_i$$
where ##\sigma_i## and ##\sigma_{i+1} = \pm 1##. The transfer matrix is,$$\mathbf {T}=\begin{pmatrix}
T(+,+) & T(+,-) \\
T(-,+) & T(-,-)
\end{pmatrix}=
\begin{pmatrix}
exp(K+L) & exp(-K) \\
(exp(-K) & exp(K-L)
\end{pmatrix}$$
where ##K=\beta J## and ##L=\beta H##. This should get you started. Also, the 1-d Ising model does't exhibit a phase transition because the spin correlations decay too rapidly as temperature goes to zero.
T(+,+) & T(+,-) \\
T(-,+) & T(-,-)
\end{pmatrix}=
\begin{pmatrix}
(exp(-K) & exp(K-L)
\end{pmatrix}$$
The second term in the Hamiltonian is only needed if there's an external magnetic field. I wasn't sure about whether the lack of phase transition in 1D is only in the spin-1/2 system, or for any total spin. Even in the 1D spin-half system the heat capacity has a peak at some temperature, but it doesn't become a singular 'spike' in the thermodynamic limit, like in real phase transition.
My apologies. I misinterpreted your question. I thought it was an homework assignment. Ising's idea was to model a 1-d ferromagnetic lattice. The purpose of the second term in the hamiltonian is to lift the degeneracy of the spin state of the valence electron. Without the second term in the hamiltonian the eigenvalue of the transfer matrix becomes zero. That means that there is no exchange of magnetic energy possible between adjacent sites in the lattice.
You propose that each lattice site have total spin = 1, but that implies that you have one spin up electron and one spin down electron per site (Pauli exclusion principle) . This would cancel the spin contribution to magnetic field per site and result in zero ferromagnetism.
Just to clarify: I'm not the one who started this thread, @Thales Castro is...
I was answering him based on my own knowledge about the subject. There are particles, or bound systems formed by several particles, which have an integer-valued spin unlike the electron which has spin-1/2. If the z-component of each spin can be 1, -1 or 0 in a 1D Ising chain, then the interaction energy of any pair of adjacent spins can be J, -J or 0.
  • · Replies 20 ·
