Spin difference between entangled and non-entangled
194 replies · 20K views · last reply
Thanks to responses I received in this thread I satisfied my curiosity regarding solid line on the graph below.
Line graph of quantum correlation from 1.00 to -1.00 against angle between detectors from 0 to 180 degrees; a dotted cosine curve and a solid, shallower curve cross zero at 45 and 135 degrees.
Fig. 1 The realist prediction (solid curve) for quantum correlation in an optical Bell test.
The quantum-mechanical prediction is the dotted curveNow I would like to understand why the result of Aspect experiment (doted line) is a proof for entanglement.
What are the most DIRECT evidences that the “entangled” photons in this experiment are indeed entangled - have perfectly opposite polarization?
Are you asking what the evidence is that they have perfectly opposite polarization after they've been measured?
Every time anyone has ever set two polarizers at 90 degrees so that we're checking for "perfectly opposite" and sent one photon into each one, they've always both passed or neither passed. That was a well-known experimental observation decades before the Aspect experiment.
Graph of quantum correlation against angle between detectors from 0 to 180 degrees: a solid curve starts at 0.50, crosses zero at 45 and 135 degrees, and reaches -0.50 at 90 degrees, with a dashed cosine-shaped curve from 1.00 to -1.00 for comparison.
The obvious thing is that the quantum predictions are matched for entangled pairs, and that is different than the predictions for other hypotheses. What more do you want? :)
Yes, this is how I should ask.
So how this result is translated into conclusion that EACH photon in the pair has "perfectly opposite" to each other (90 degrees difference) polarization.
The Aspect's (and others') experiment is statistical in nature (performed on series of photons). The wave function, is also, as I understand, could be interpreted statistically - say it applies only to the average result. In this case, in absence of perfect correlation (entanglement) for EACH photon pair we still may be ended up with the statistically perfect correlation - doted line and will be in agreement with the statistical interpretation of QM.
If this is true, would it undermine "spooky" action on distance?
Could this match, between QM and the experimental results for entangled pairs, be limited to the statistical average only? Do we have any ground to extend this statistical result into behavior of individual pairs?
miosim said:
... The wave function, is also, as I understand, could be interpreted statistically - say it applies only to the average result. In this case, in absence of perfect correlation (entanglement) for EACH photon pair we still may be ended up with the statistically perfect correlation - doted line and will be in agreement with the statistical interpretation of QM.
No. When the angles are integer multiples of 90 degrees, there is perfect correlation (or anti-correlation) for every pair. This demonstrates entanglement very nicely. At other angles, the statistics support quantum non-locality via agreement with predictions. As to action at a distance: this is dependent on your interpretation.
Before follow your explanation I have a question about Fig.1.
I thought that at 90 degrees between polarizer QM prediction should be the same as realistic prediction. Why the realistic prediction on the Fig. 1 is only 50%?
By talking to my self I understood why it is 50%.
If the perfect correlation of entangled photons that passes two polarizers at 90 degrees was observed before Aspect experiment, do we really need Bell's theorem, rotating polarizers, and other complex experiments to prove entanglement. Apparently even for polarizers at 90 degrees the realistic prediction would never explains 100% correlation ?
That is not the case. It depends on the particular realistic theory. As mentioned previously, that solid line is one possibility and it has certain advantages. Others do other things well. None of them match QM. So you have asked different questions: a) what proves or demonstrates entanglement; and b) why don't local realistic theories match QM vis a vis entanglement. The answer to a) is perfect correlations demonstrate entanglement. Matching the predictions of QM at other angles (where there are no perfect correlations) demonstrates entanglement too.
The answer to b) is that in local realism, there is no ongoing state of entanglement. It might be something, but it isn't entanglement because separated particles can have no ongoing physical connection. And not surprisingly, local realism cannot mimic entanglement (as we now know).
So far I able to follow your explanation, but I probably missing something.
If the result of the the perfect correlation of entangled photons (that passes two polarizers at 90 degrees) was a well-known decades before the Aspect experiment, what was the explanation for this phenomenon at that time? How long ago the first experiment of this kind was performed? Did Einstein know about result of this experiment?
As far as I know, the first entanglement experiments were in the 70's. So Einstein did not know. Entanglement of photons and entanglement in general was not well understood for many years after EPR. The perfect correlations of EPR were not really specific, more general and theoretical.
Keep in mind that the conflicts between local realism and QM were not known until after 1965. So for many years, no thought was given that entanglement statistics disprove local realistic theories.
In case of experiment with two polarizers at 90 degrees it isn't just a statistic; it should be demonstrated (practically) for each individual pair passes polarizer.
So, if at the time of EPR paper, someone confront Einstein with the Gedankenexperiment about entangled photons that passes two polarizers at 90 degrees his prediction (most probably) would be 50% correlation, while the supporters of the mainstream QM would come up with 100% correlation?
How difficult would be performing this experiment in 1935?
Einstein would say that (100% correlation) was consistent with a local hidden variables theory (and proof of entanglement, which it is). The 50% would be a different local hidden variables theory (no entanglement though). There are an infinite number possible, and they all disagree with experiment at one angle or another. The 100% ones needed Bell to show us the flaw.
Because Einstein didn't believe in entanglement he would be in difficult position to offer (not exotic) realistic explanation for the 100% correlations. I am still puzzling why Bohr and others didn't challenge EPR paper with this simple Gedankenexperiment. I guess I still missing some important details.
Let's conceder this Gedankenexperiment and to follow all events that lead to the 100% correlation for the detectors set at 90 degrees. I will conceder two scenarios:
1). When the entangled pair interacts with the closer polarizer the wave function collapses yielding two independent photons having perfectly opposite polarization that also perfectly aligned with corresponding polarizer. In this case both photons will be detected and this contributes to the 100% correlation.
2). However if after the wave function collapse the first photon is not fully aliened with the detector it still may pass detector (with some probability) however I am not sure that this insure the 100% pass for second photon. This pair may erode "picture perfect" 100% correlation.
It is why I don't see how we can observe 100% correlation in this experiment even entanglement is true. What I am missing?
If the polarisa that is closer to the source interact with entangled particle
In the his prediction (
As I understand the 100% correlation result from the fact that when one photon
