Char. Limit
- 23
What is Planck-close, though? Are you talking about h?
Char. Limit said:What is Planck-close, though? Are you talking about h?
Char. Limit said:Heisenberg said you can't exactly locate anything. Thus, the electron's position is a permanent unknown.
peteratcam said:Just my two cents:
Spin is intrinsic angular momentum - in some regards a completely classical concept, although very hard to imagine because it is very unfamiliar in the classical context. (For the experts, nothing prevents you doing a classical field theory with dirac spinor fields - the representation structure of the Poincare symmetry is the same as ever)
Char. Limit said:The property is true of intrinsic angular momentum because the particle itself has a charge, right?
Char. Limit said:This also explains it to me very well. Thanks.
bigubau said:There's no reason to talk of spin in the context of classical physics. Of all the fields we know, only 2 (em and gravitational) have a classic-level existence (they are the only interactions with infinite range). They're interaction fields to be more precise.
As I said in another thread, there's no spin outside flat space relativity, there's no spin outside quantum mechanics.
alxm said:No, charge is a separate property. Neutrons have no charge and half spin. So do neutrinos. Photons have no charge and integer spin.
Char. Limit said:I don't understand electron spin. What is it? Does spin have units? Does it do anything like electric charge or gravitation does? What does it represent? Any help for a "wikipedia physicist" (as I call myself) would really help. Just keep in mind: I haven't taken a class in QM.
watcher said:according to milo wolff. in an all wave model, electron spin is as a spherical rotation...
http://www.youtube.com/watch?v=uKrM...2E390874&playnext=1&playnext_from=PL&index=42
Spherical Rotation
Rotation of the inward quantum wave at the center to become an outward wave is an absolute requirement to form a particle structure. Rotation in space has conditions. Any mechanism that rotates (to creates the quantum "spin") must not destroy the continuity of the space. The curvilinear coordinates of the space near the particle must participate in the motion of the particle. Fortunately, nature has provided a way - known as spherical rotation -
After two turns, space regains its original configuration. This property allows the electron to retain spherical symmetry while imparting a quantized "spin" along an arbitrary axis as the inward waves converge to the center, rotate with a phase shift to become the outward wave, and continually repeat the cycle.
The required phase shift is a 180o rotation that changes inward wave amplitudes to become those of the outward wave.
It is an awesome thought that if 3-D space did not have this geometric property of spherical rotation, particles and matter as we know them could not exist.
You should be more careful about what sources you're referring to at Physics Forums. This Milo Wolff doesn't seem to be an actual physicist, and more importantly, he doesn't seem to publish in peer reviewed journals. Also, the things you said about electron spin and rotations are very misleading.watcher said:according to milo wolff. in an all wave model, electron spin is as a spherical rotation...
Spherical rotation is an astonishing property of 3-D space. It permits an object structured of space to rotate about any axis without rupturing the coordinates of space. After two turns, space regains its original configuration. This property allows the electron to retain spherical symmetry while imparting a quantized "spin" along an arbitrary axis as the inward waves converge to the center, rotate with a phase shift to become the outward wave, and continually repeat the cycle.
Photons are indeed particles that possesses spin, but being massless, their spin behaves in a way that is a little different from the more usual spin of a massive particle (electron or proton) as necessarily spinning about its direction of motion.
ytuab said:I think it is quite natural for us to dream of a real particle and a real spinning of the electron. (These are inseparable.)
Your statement is very interesting, but I'm afraid it is imposibble to treat the spin as a real spinning in the quantum mechanics(QM).
You said the electron spin is "a spherical rotation". But how fast is the electron rotating(spinning) ?
I think if we can consider an electron as a real particle with real spinning in QM, we could have already done this a long time ago (in 1920's ~1930's). If you use some "new instruments" which could not be made at that time, this is a different matter.
Fredrik said:You should be more careful about what sources you're referring to at Physics Forums. This Milo Wolff doesn't seem to be an actual physicist, and more importantly, he doesn't seem to publish in peer reviewed journals. Also, the things you said about electron spin and rotations are very misleading.
I sympathize with this to some degree, but the policy here at PF is to only discuss things that have already been judged, by well-known and respected science journals. So this is actually against the forum rules. The James Randi Educational Foundation has a good forum for those who want to discuss material that isn't allowed here.watcher said:i don't like to appear like i am pitching for milo but his biography is in the internet, judge for yourselves if his "not so mainstream science idea of all wave model of matter" is not worthy of physics forum.
Fredrik said:I sympathize with this to some degree, but the policy here at PF is to only discuss things that have already been judged, by well-known and respected science journals. So this is actually against the forum rules. The James Randi Educational Foundation has a good forum for those who want to discuss material that isn't allowed here.
watcher said:sorry if my post mislead you. let me try again.
space is what rotates in a spherical way. spin is the result of phase shift ( from up spin to down spin, vv) due to the meeting of the so called advanced and retarded emf waves (feynman),
the electron is the particle effect at the center of these waves or the amplitude of these quantum waves.
During this period Schrödinger turned from mainstream quantum mechanics' definition of wave-particle duality and promoted the wave idea alone causing much controversy. - wiki
The particle can only appear as a limited region in space in which the field strength or the energy density are particularly high. (Albert Einstein, Metaphysics of Relativity, 1950)
passingthru said:A study of particle physics reveals that electrons have internal structure, if I understand it correctly, and that's a big if, three quarks.
Char. Limit said:OK, I think I might be getting a (very) basic idea now. One thing confuses me though: how can electron "spin" be synonymous with charge, if an electron has one possible value for charge, and two for "spin"?
Also, in the equation for the post above, what are those strange | and > symbols?
haael said:Also, how spin number translates into vector direction? Photons, as vectors, point into some direction, right? I thought that spin states -1, 0, 1 are "base vectors", but the numbers don't quite match.
OK, thanks, but what about spin 2 tensors? There are 9 numbers that build up a tensor, but only 5 spin states.Notice that the swirling clouds have a complex phase and maybe you can see that if you add together the physicists +1 and -1 states you get the chemists "vector state" along the x or y-axis (depending if you add or subtract).
