Spinning Disk (circular motion)
A disk with a diameter of 0.07 m needs to rotate at 9.97 revolutions per second to achieve an acceleration of 14 g's at its outer edge. The angular velocity calculated is 62.64 rad/sec. For a point halfway between the axis and the edge of the disk, the speed is determined to be 1.09 m/s. The period of rotation for this point is simply the inverse of the frequency found. Overall, the calculations involve using centripetal acceleration and angular velocity formulas to derive the necessary values.
Trentonx
A disk with a diameter of 0.07 m is spinning about an axle perpendicular to the disk and running through its center.
a) How many revolutions per second would it have to rotate in order that the acceleration of the outer edge of the disk be 14 g's (i.e., 14 times the gravitational acceleration g)?
b) For the frequency determined in part (a), what is the speed of a point half way between the axis of rotation and the edge of the disk?
c) At this same frequency, what is the period of rotation of this "halfway point"?
a_c=v^{2}/r
v=r \omega
a=r \alpha
I tried substituting the angular velocity in the centripetal acceleration, setting it equal to 14g
137.2=(rw)^2/r
w=44.27 rad/sec (I think), then dividing by 2pi for rev/sec.
That didn't work. So I'm stumped. our professor hasn't lectured on this at all, so I'm really lost on what to do.
So you used a = (rw)^2/r = rw^2
or w = sqrt(a/r) ?
r = 0.035
It works out to 62.64 rad/sec or 9.97 revs/sec for me
No, actually what I used was the diameter, not the radius. So now I have a and b, but what is a "period of rotation"? I know the speed at that point and the radius, so that's the circumference, should it be the speed divided by circumference?
V=1.09 m/s
r=.0175
C=.1099m
I was making it too complicated. Just 1 over the frequency that we found. Thanks for your help.
  • · Replies 18 ·
  • · Replies 24 ·
9K
