Spinning ice skater (angular momentum)
The discussion centers on the application of the conservation of angular momentum and the parallel-axis theorem in calculating the rotational speed of a figure skater. The skater, weighing 45 kg, initially spins at 1.0 rev/s with arms outstretched. Upon raising her arms, the moment of inertia changes, necessitating the use of the parallel-axis theorem to accurately compute the new rotational speed. The final calculation yields a reduced speed of 0.98 rev/s, confirming the expected outcome of increased moment of inertia due to arm position.
  • Understanding of angular momentum conservation principles
  • Familiarity with moment of inertia calculations
  • Knowledge of the parallel-axis theorem
  • Basic physics of rotational motion
  • Study the application of the parallel-axis theorem in various rotational systems
  • Explore detailed examples of moment of inertia for complex shapes
  • Learn about the effects of mass distribution on rotational dynamics
  • Investigate real-world applications of angular momentum in sports and engineering
Physics students, educators, and anyone interested in understanding the principles of rotational motion and angular momentum in practical scenarios.
Cfem
A 45 kg figure skater is spinning on the toes of her skates at 1.0 rev/s. Her arms are outstretched as far as they will go. In this orientation, the skater can be modeled as a cylindrical torso (40 kg, 20 cm average diameter, 160 cm tall) plus two rod-like arms (2.5 kg each, 66 cm long) attached to the outside of the torso. The skater then raises her arms straight above her head, where she appears to be a 45 kg, 20 cm diameter, 200 cm-tall cylinder.
Conservation of angular momentum
Moment of Inertia
Li = (Ib + 2(Ia))wi
wi = 6.2831 rad/s
Ib = (1/2)(40)(.1)(.1)
Ia = (1/3)(2.5)(.66)2
Lf = (If)(wf)
If = (1/2)(45)(.1)2
Li = Lf
Solve for wf
wf = (.926)(6.2831)/(.225)
Any ideas where I went wrong?
The arms are attached at the outside of the torso, so I_a is wrong.
Okay, I get that I should use the parallel-axis theorem, but I'm a little confused about how to apply it.
Would it be the moment of inertia as I calculated it + the mass of the rod times the radius of the skater's torso?
The definition says that you should take the moment of inertia about the center of mass and then add the distance of the new axis (times the mass), so I'm a little confused with the terminology.
No. For the parallel-axis theorem you need the moment of inertia around the center of mass.
(and you add that to the mass of the rod times the square of the distance from the center of mass to the axis of rotation
Ugh.
Ia = (1/12)(2.5)(.12) + 2.5(.432)
Plugging in the new values gives me a final rotational speed of .98 rev/s, which is slower.
I hate rotational motion.
  • · Replies 16 ·
  • · Replies 20 ·
13K
