Spring constant based on change in potential energy
The discussion revolves around determining the spring constant based on changes in potential energy as a spring is decompressed. The original poster presents a problem involving energy stored in a compressed spring and the energy after decompression, with specific values given for energy and displacement.
  • Participants explore the relationship between potential energy and spring constant using equations related to energy stored in springs. There are attempts to manipulate these equations to find the spring constant, with some participants questioning the correctness of terms and units used in the calculations.
Several participants are actively engaging with the problem, offering insights and corrections regarding the equations and units. There is a recognition of potential errors in the original poster's approach, and alternative methods are suggested. The discussion is ongoing, with various interpretations and calculations being explored.
Participants note the importance of using consistent units, particularly emphasizing the need to convert distances to meters when dealing with energy in Joules. There is also mention of a sign error in the original setup that may affect the calculations.
sanctifyd83
A compressed spring has 138 J of energy stored in it. When it is decompressed by 125 cm, it now stores 82.6 J of energy. What is the spring constant
General:
ΔU = 1/2kxf2 - 1/2kxi2
U(x) = 1/2kx2
U1 = 1/2kx12
U2 = 1/2k(x1 + 1.25 m)2
U1 = 1/2kx12
k = 2U1/x12
U2 = 1/2 (2U1/x12)(x1 + 1.25 m)2
U2 = U1/x12 (x12 + 2.5m x1 + 1.5625 m2
U2 = U1 + (2.5 m x1/x1) + (1.5625 m2 U1/x12)
x12 ΔU = (2.5m U1/x1 + 1.5625m2 U1/x12) x12
ΔU x12 = 2.5m U1 x1 + 1.5625m2 U1
Substitute values and get them all to one side:
55.4J x12 - 345Jm x1 - 215.625Jm2 = 0
Quadratic formula gives:
x1 = 6.8 cm and -.57 cm
138J = 1/2k (.068 m )2
276J/.00462 m2 = 59740 N/m = k? Obviously that can't be right.
Any help on this would be great!
This equationis wrong; the middle term does not have units of energy.
I continue to recommend that people leave numbers out until the end, and that they check dimensions term-by-term everywhere.
Hello sanctifyd83. Welcome to PF!
Is ΔU positive or negative?
Thank you, rude man. Yes I input the middle term incorrectly. It should be 2.5 m/x1. I did it correctly when I worked it out though, I don't believe it affects the rest of my "solution."
Thank you for that. Yes, the value ought to be negative. This gives the value for x1 slightly different negative values which, when squared, become positive. The result is still an extremely large value for k.
x1 would equal -5.5 or -.7
Using -5.5 k would be around 90000N/m and -.7 would give an even larger number.
I agree with the -5.5 m. (You should see a reason why you have to throw out -0.7 m)
But I don't see how you're getting such a large value for k. Can you show how the x1 = -5.5 m leads to k = 90000 N/m?
Forgive me as I'm trying to understand the material but I think that x1[/SUB's units would be in cm? If this is the case -5.5 cm turns into -.055 m which when squared becomes .003 m2. 276J/.003 m2 = 92000N/m.
How do you know what the variable's initial units are? I assumed we were working with it in cm since the problem initially had the length units in cm. I know that I converted it to meters but it seems that the quadratic function canceled all units except the ones for x1.
The energy is given in Joules, an SI unit. Thus, distances should be in meters. So, it's good that you converted the 125 cm to meters. When you solve the equations, the distances will still be in meters.
EDIT: Take your equation 55.4J x12 + 345Jm x1 + 215.625Jm2 = 0
The Joules cancel out. Can you then see by inspection of the remaining units that x1 must have units of meters?
That absolutely makes sense, I couldn't quite grasp that. It seemed like I was just arbitrarily inputting units. Thanks so much.
Maybe I'm missing something:
[tex]138 = \frac{1}{2}kx_0^2[/tex]
[tex]82.6 = \frac{1}{2}k(x_0-1.25)^2[/tex]
Divide one equation by the other to get x0 (the k's cencel). Then find k from the first equation.
Chet
I'm with you Chestermiller
Chet
Yes, this is much nicer. The OP had already set up and worked the problem correctly except for a sign error, so I didn't want to start over.
But it's certainly worth while to point out a better method of solution, and I should have done that. :redface:
Thanks.
Thanks so much everyone. It helped out a lot.
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 17 ·
