Spring constant, find height of projectile
A 48-gram dart is launched vertically from a catapult with a spring constant of 350 N/m, initially stretched by 21 cm. The velocity of the dart upon leaving the catapult is calculated using the formula v = d√(k/m), resulting in approximately 17.93 m/s. The height reached by the dart is then determined using the equation h = v^2 / 2g, yielding a height of about 16.38 m. Discussions highlight the importance of considering energy conservation, including kinetic, gravitational potential, and elastic potential energy, rather than solely focusing on velocity. Overall, the approach to solving the problem can be improved by emphasizing energy conservation principles.
subopolois
A 48 gram dart is shot vertically upwards from a catapult with a spring constant of 350 N/m. The catapult is initially stretched from the equilibrium point by 21 cm. What is the height above the starting point reached by the dart?
KE=PE, rearranging to find h gets h= v^2/2g
find the velocity as it leaves the catapult as v= d(sqrt(k/m))
v= 0.21m (sqrt(350Nm/0.048kg))
= 17.93 m/s
h= (17.93m/s)^2 / 2(9.81m/s^2)
= 16.38 m
does this seem right?
Your work looks good. But did you answer the specific question that was asked?
Sorry, subopolois. I read your post too quickly.
When you calculated the speed at which the dart leaves the catapult, did you take into account the increase in gravitational potential energy of the dart? How did you get the formula v = d√(k/m)?
I did not, how would i do that?
I did take gravity into account when i found the height...
You could find the speed at which the dart leaves the catapult by using conservation of energy. You will need to include kinetic energy, gravitational potential energy, and elastic potential energy.
There is a better approach to the problem. You don't need to find the speed at which the dart leaves the catapult. Is energy conserved overall between the point of release and the point where the dart reaches the highest point?
