Spring system inside an accelerating box
The problem involves a mass suspended from a vertical spring inside an accelerating box. The objective is to determine how much closer the equilibrium position of the mass moves to the bottom of the box when the box accelerates upward.
  • Participants discuss the initial equilibrium position of the mass and question the assumptions regarding its location. There is an exploration of the relationship between the spring's natural length and the loaded position of the mass.
Some participants have provided clarifications regarding the assumptions made about the spring's length and the mass's position. There is recognition of the need to differentiate between the unloaded spring length and the position when the mass is at equilibrium. The discussion appears to be productive, with participants reflecting on their understanding and reasoning.
The problem does not specify the initial position of the mass, leading to assumptions about its location. Participants are encouraged to consider the implications of these assumptions on the overall analysis.
physics517
A mass m is resting at equilibrium suspended from a vertical spring of natural length L and spring constant K inside a box.
The box begins accelerating upward with acceleration a. How much closer does the equilibrium position of the mass move to the bottom of the box?
f=kx
f=ma
so this is my f=ma statement
kx-mg=ma
then i solved for x to get x= m(a+g) / k
but this answer is wrong and the correct answer is
ma / k
You are looking for the change in the mass' position from the initial equilibrium position, after the box has begun accelerating. What was its initial position?
In other words, what was the equilibrium position of the mass before the box was accelerated?
hmm the problem doesn't specify that location.
Cant we just assume it to be at location 0
Sure. You can assign your zero position to that location. Just keep in mind that it isn't the same location as the end of the relaxed, unloaded spring.
Recapping what's happening:
1. Box at rest. Spring unloaded, natural length L.
2. Box at rest. Spring loaded with mass M, settles at equilibrium.
3. Box accelerating. Spring stretches more, assumes new equilibrium.
The question is (essentially) asking for the amount of stretching that takes place between items 2 and 3.
I think my problem was that i assumed L to be the spring's length when it was loaded. But what you stated makes sense now and it leads to the right answer.
excellent help. you gave me info but just enough to make me think and understand it
thank you
