What Happens to Sqrt(n+1) - Sqrt(n) as n Approaches Infinity?
  • Thread starter Thread starter tcbh
The limit of the expression $\lim_{n\to\infty}\sqrt{n+1}-\sqrt{n}$ approaches 0 as n approaches infinity. The discussion highlights the use of the Mean Value Theorem and algebraic manipulation techniques, specifically multiplying by the conjugate $\frac{\sqrt{n+1} + \sqrt{n}}{\sqrt{n+1} + \sqrt{n}}$ to simplify the limit calculation. Participants confirmed that the expression can be bounded by $\epsilon$ for sufficiently large n, specifically for $n > \frac{1}{4\epsilon^2}$. This formal approach solidifies the understanding of limits involving square roots.
  • Understanding of limits in calculus
  • Familiarity with the Mean Value Theorem
  • Basic algebraic manipulation techniques
  • Knowledge of epsilon-delta definitions of limits
  • Study the Mean Value Theorem in detail
  • Practice limit calculations involving square roots
  • Explore epsilon-delta proofs for limits
  • Learn about bounding techniques in calculus
Students studying calculus, particularly those focusing on limits and continuity, as well as educators looking for examples of limit proofs involving square roots.
tcbh
none
The answer is obvious, but I'm having trouble doing it formally. The best I can come up with is setting it equal to some tn, moving -\sqrt(n) to the other side and squaring both sides. Then somehow showing that tn--> 0.
There's a classic hint on this type of problems. To multiply by 1/1 written in a smart manner, that is involving radicals and <n>. Then taking the limit would be a formality.
If what I said is not obvious, I'll give you a new hint.
Have you tried using the mean value theorem on \sqrt{n+1}? It should come out quickly that way.
Thanks for the help!
I tried multiplying by\sqrt{n}/\sqrt{n}.
Eventually I ended up with n(\sqrt{1+1/n}-1)/\sqrt{n}
Again, it seems pretty clear that the top goes to 0, but I feel like I should be able construct a N based on some \epsilon so the the expression is always less than \epsilon for n > N. I'm not really sure how to go about constructing that N.
ahh, I see.
f'(x) = \sqrt{n+1} - \sqrt{n} for some x\in(n, n+1)
f'(x) = 1/2\sqrt{x}
Then for x\geq1/4\epsilon^{2}, 0<f"(x)<\epsilon
Does that look right (well the tex seems to be a mess, lol)?
Well, it's still not solved, because you get a new infinity*0 limit.
The next hint is (a+b)(a-b) = a^2 - b^2.
Following along the lines of bigubau's hint, multiply your original expression by 1 in the form of
tcbh said:
ahh, I see.
f'(x) = 1/2\sqrt{x}
This looks right, you just need to use n instead of x technically, so it would be
0\leq\sqrt{n+1} - \sqrt{n}\leq\epsilon \ \ \ \forall n&gt;\frac{1}{4\epsilon^2}
  • · Replies 20 ·
