Square of the sum of two orthonormal functions?
The discussion centers on calculating the square of the sum of two orthonormal functions, Ψ and Φ. Participants clarify that the correct expression to evaluate is |Ψ + Φ|^2, which represents the inner product rather than simply squaring the sum. It is emphasized that the inner product leads to a scalar result, while squaring the functions directly would yield another function. The importance of interpreting the squaring operation correctly is highlighted, as it affects the outcome of the calculation. Overall, the conversation underscores the distinction between inner product notation and standard multiplication in the context of orthonormal functions.
Boltzman Oscillation
Given:
Ψ and Φ are orthonormal find
(Ψ + Φ)^2
None
Since they are orthonormal functions then can i do this?
(Ψ + Φ) = (Ψ + Φ)(Ψ* + Φ*)?
Boltzman Oscillation said:
Given:
(Ψ + Φ)^2
None
Yes. Now go ahead. Multiply it and apply what you know.
Oh goodie!
ΨΨ* + ΦΦ* + ΨΦ* + Ψ*Ψ
The dot product of two orthonormal functions is 0. The dot product of two equal functions is 1.
1 + 1 + 0 + 0 = 2
Likes Delta2 and fresh_42
There are some typos in this thread, most important one is that we want to find
##|\Psi+\Phi|^2## not just ##(\Psi+\Phi)^2## , right?
Does the squaring operation indicate scalar/vector/etc. multiplication, or does it indicate the inner product under which you have orthonormality? After all, ## \sin n\pi x ## and ## \sin m\pi x ## for ## m\ne n ## are orthogonal (and also normal with the appropriate coefficient), and:
## {(\sin n\pi x + \sin m\pi x)^2} = {(\sin n\pi x + \sin m\pi x)^*}(\sin n\pi x + \sin m\pi x) = {\left| {\sin n\pi x} \right|^2} + {\left| {\sin m\pi x} \right|^2} + {(\sin m\pi x)^*}\sin n\pi x + {(\sin n\pi x)^*}\sin m\pi x ##
I apologize if my pedantry glosses over some context, but I'm just trying to be careful.
Likes Delta2
Yes. I was asked to normalize and equation and it contained two orthonormal functions. I forgot how important the absolute value is.
Technically, it is not the absolute value which counts! It is only a common indication, that ##\psi \chi = \langle \psi , \chi \rangle## is meant to be the multiplication. One could as well simply define the multiplication given by the inner product and then no absolute value would be necessary. So it's the way the square has to be interpreted which counts, not the shape of the brackets.
I thought the absolute value's function was to make every section of the function positive so that the integral over that function doesn't cancel out. Kinda like taking the energy of a wave. Right?
No, this is not right. It only makes the resulting values positive, not the individual function values. The square does the same.
The point is, that - normally - ##|\psi + \chi|^2=\langle \psi + \chi, \psi + \chi \rangle## and ##(\psi + \chi)^2= \psi^2 + \psi \chi + \chi \psi + \chi^2## where the former leads to a scalar as result and the latter to another function. In cases where the latter doesn't exist or isn't defined, resp. given, then only the former is left as possibility. By the way you stated the question, it is automatically implied that we are talking about the inner product, simply because no other product was available.
