Srednicki QFT chapter 8 question
  • Level: Graduate
  • Thread starter LAHLH
    Qft Srednicki
LAHLH
Hi,
In chapter 8 Srednicki employs the [tex]1-i \epsilon[/tex] trick. He multiplies the Hamiltonian desity,
[tex]H=\frac{1}{2} \Pi^2+\frac{1}{2}(\nabla\phi)^2+\frac{1}{2}m^2\phi^2[/tex]
by this [tex]1-i \epsilon[/tex], and says it's equivalent to if we replaced m^2 with [tex]m^2-i \epsilon[/tex]. I can't see how this is?
Thanks
He explains this in detail in the earlier chapter on the harmonic oscillator.
In chptr 7, it's completely different,
[tex]H(P,Q)=\frac{P^2 m^{-1}}{2}+\frac{1}{2}m\omega^2 Q^2[/tex]
So multiplying by [tex]1-i\epsilon[/tex], gives :
[tex]H(P,Q)=\frac{P^2 (1-i\epsilon)m^{-1}}{2}+\frac{1}{2}(1-i\epsilon) m\omega^2 Q^2[/tex]
So directly you can see this is equivalent to if we used [tex]m^{-1} \rightarrow (1-i\epsilon)m^{-1}[/tex] and [tex]m\omega^2 \rightarrow (1-i\epsilon)m\omega^2[/tex]
I fail to see how to perform in a similar process to get Srednicki's mass substitution for the H in my first post. Thanks.
Hi LAHLH,
I would recommend not trying to take Srednicki's comment too literally. A useful point of view is the following. The purpose of the [tex]i \epsilon[/tex] is to get the pole structure right in the propagator. To make sense of what Srednicki is saying, try to determine if modifying only the mass by [tex]i \epsilon[/tex] is sufficient to modify the pole structure so that integrating along the real line is the "right" contour.
