Dong Aleta
- 29
I want to know of any standard method for identifying (and possibly quantifying) the species contained in a solid mixture sample. Thanks in advance!
The standard method for identifying and quantifying species in solid mixtures, particularly in precipitates formed from K2HPO4 and CaCl2, involves a comprehensive analysis of the sample's composition. Qualitative identification is prioritized, requiring detailed knowledge of the sample's organic or inorganic nature, functional groups, and various physical properties such as melting points, boiling points, solubilities, and densities. Analytical techniques such as FTIR, NMR, MS, UV-Vis, and metals analysis methods like Flame AA, ICP, XRF, PIXE, and SEM are essential for accurate characterization. The process of reverse engineering complex mixtures is inherently challenging and necessitates the separation of individual components for thorough analysis.
PREREQUISITESChemists, materials scientists, and laboratory technicians involved in the analysis of solid mixtures and precipitates, particularly in the context of calcium phosphate research.
Dong Aleta said:I want to know of any standard method for identifying (and possibly quantifying) the species contained in a solid mixture sample. Thanks in advance!
I apologize for not specifying. I want to precipitate hydroxyapatite (HAP) by mixing two solutions of K2HPO4 and CaCl2 at initial pH 9~9.5. I did some literature review and found out that apparently, we know of other calcium phosphate crystals can precipitate other than HAP. But I want to be able to quantify (if possible) how much HAP was precipitated in the resulting precipitate (after filtration and drying).Kevin McHugh said:You are SOL. Unless you know a whole lot about your sample. Qualitative identification comes first, then quantitation. Is your sample organic or inorganic or both? What functional groups does it contain. You need a slew of data. You need melt points, boiling points (if applicable). You need solubilities. You need densities. You need spectroscopic data, FTIR, NMR, MS, UV-Vis. You might some form of metals analysis, Flame AA, ICP, XRF, PIXE, SEM.
You need to separate individual components and gather all the data on the individual compounds. Reverse engineering complex mixtures is quite a challenge.
Actually, it's a precipitate after mixing solutions of K2HPO4 and CaCl2, after filtration and drying.Bystander said:Cake mixes? Or, actual/real mixtures?
