Starting Hydraulics Recommendations?
  • Thread starter Thread starter microbiek
    Hydraulics
Students studying hydraulics are seeking introductory books that explain basic principles clearly, as existing library resources often assume prior knowledge. "Urban Drainage" by Butler & Davies is recommended for part of the course but lacks comprehensive introductory material. Basic hydraulics concepts can typically be found in Physics and Fluid Mechanics textbooks. One suggested resource is "Essentials of Engineering Hydraulics" by J.M.K. Dake, which offers a more accessible approach with less emphasis on mathematics. The discussion highlights a need for clearer introductory texts in hydraulics education.
microbiek
Hi,
We've just started studying hydraulics at my uni. I'm finding the lecturer is going way to
fast and was just wondering if anyone knows of a good hydraulics book that introduces you to the basic principles and concepts? I was in our library the other day an the books there semed to presume you had the basics...it felt as if they were missing something.
Thanks for any recommendations!
microbiek said:
Hi,
Doesn't the course require or recommend a text?
CS
yes it recommend "Urban Drainage, Butler & Davies (E & FN Spon). " whch is fine for half the course the second half... but i need something for an introduction to the basics etc.
Basic hydraulics would most likely be covered in your Physics book and also most Fluid Mechanics books.
CS
yea its a bit like any other subject but structural analysis is covered a lot better in some books than others...im looking for the name of a book that covers the intro to hydraulics well although I've only looked at abou 3 or 4 books I've found them lacking in coherence
Essentials of Engineering Hydraulics by J M K Dake
has more english and less maths than most, although you will eventually need the maths.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
80K
