How Does State Space Design Compare to Classical PID Controllers?
State space design offers advantages for managing complex MIMO and non-linear systems, providing a framework that captures interrelated outputs more effectively than classical PID controllers. It does not completely replace PID controllers; instead, it often works alongside them. In practice, a central MIMO state space model is used to address the system's complexity, while simpler classical control methods can be applied to individual inputs and outputs. This hybrid approach allows for more comprehensive control strategies. Understanding these distinctions is crucial for effective controller design in advanced systems.
MikeSv
Hello everyone.
Iam just Learning about State space representation and controller design and have a fundamental question about the difference between classical Control theory and modern Control theory.
I understood the state space is of advantage when dealing with MIMO systems or non-linear systems, but:
What exactly is state space design? Does it replace i.ex. a classical PID controller?
Thanks in advance,
kind regards,
Michael
Complicated systems are often a mixture of approaches. There are usually several outputs that need to be controlled and they are interrelated. The central controller of a MIMO system can not be analysed as a simple PID controller. The physics of the system may include relationships between states that are hard to represent without a state space model. That forces you to include a central MIMO state space model. But the individual inputs and outputs of that model may be simpler. That leads you to surrounding your MIMO state space model with several classical Laplace transforms which pre-process the individual inputs and post-process the outputs.
Likes dlgoff
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 21 ·
14K
9K
  • · Replies 22 ·
22K
