Engineering Calculate Static Equilibrium: SOH/CAH/TOA?
In calculating static equilibrium, the use of SOH/CAH/TOA depends on the reference angle. If the angle is measured from the x-axis, cosine is used for the x-component and sine for the y-component. Conversely, if the angle is measured from the y-axis, sine is used for the x-component and cosine for the y-component. It's essential to recognize that angles not aligned with either axis will require careful consideration of the components. Understanding the relationship between sine and cosine based on the angle's reference is crucial for accurate calculations.
Mason98
Sin for Y axis and Cos for X axis?
Sin = opp/hyp Cos = Adj / hyp
When calculating static equilibrium, i know that you have to split for example, F1 into F1x and F1y. when using soh/cah/toa is it always SIN for the Y axis and always Cos for the X axis? I've been following this method and getting it wrong some times it's really stressing me out, Thanks for any help in advance.
No. It all depends on what angle you are using. If the angle is with respect to the x-axis, then fine: The x-component would use cosine, etc. But if the given angle is with respect to the y-axis, things are reversed.
Remember that sinθ = cos (90° - θ).
Likes Mason98
so that is how in the picture Fax is sin because the angle given is in respect to the y-axis which would mean to use sin?
Exactly!
Likes Mason98
Doc Al said:
Exactly!
Thank you very much! I appreciate your help :)
But if you adopt this as a new rule-of-thumb, you'll still be in a pickle when the problem gives you an angle which is relative to neither the x nor y axis.
  • · Replies 31 ·
