Static Variables: Are They Really Static?
  • Thread starter Thread starter ptabor
    Static Variables
Static variables in C++ are intended to retain their values between function calls, but issues can arise, especially in multi-process environments like MPI. The observed behavior of the static array being reset to zeros on subsequent calls may be due to the initialization logic or the way processes are managed in MPI, where each process may treat the first invocation differently. It is suggested to verify the "first time through" condition and consider whether the program is multithreaded, as race conditions could affect variable states. Moving static variables outside the function is not recommended due to potential global clutter, but it may help in troubleshooting the issue. Properly implemented, static variables should not be reinitialized on each call, indicating a possible underlying problem in the code structure or execution context.
ptabor
I am doing some work using static variables - and they apparently aren't static.
void function ( arguments ) {
static float Y_kn[101][7];
if (first time through) {
initialize Y_kn
return;
use Y_kn to make some calculations
this function is called many many times (hundreds) and for the first time through Y_kn gets initialized properly. On subsequent calls the array is set to all zeros. I could initialize it every time I go through, but I thought that was the point of static variables - initialize them once and they keep the same values for the duration of the program.
This is being compiled on a unix system using mpiCC
Perhaps someone can provide some insight, because I'm stumped.
Technology news on Phys.org
Just out of curiosity how can you have a static variable declared within a method? Tought that is not possible.
Code:
function void something(...){
static int xyz = ...;
Shouldn't one do
Code:
xyz = ...;
instead?
Static variables are initialized to zero by default, unless explicitly initialized in the declaration statement. What is happening in your case is the compiler is generating code to re-zero out the static variables each time the function is called. I'm not sure what the "proper" behavior for static variables inside a function is. As mentioned, try moving the static variable(s) outside the function and they should only get zeroed (or initialized) at startup time.
Given that you are using MPI, it could be that the "first time through" condition is only valid once in one process, whereas you have as many default initializations as there are processes. Is the problem persisting if you use only one process?
In any case, conforming C++ compiler should not reinitialize to zeros on each function invocation, and it is generally not a good idea to put the variable outside (cluttering the global level).
Chusslove Illich (Часлав Илић)
It's hard to tell what you did wrong without seeing the code. Could you make a small example that exhibits the behavior you're seeing, and post it to the forum?
Is your program multithreaded? Have you safeguarded against race conditions? How are you determining when it's the first time through, and when it's not?
The following behaves correctly (I think) using Borland C:
Code:
#include <iostream>
using namespace std;
void f(bool first)
	static int x;
	if (first)
		x = 123;
	cout << x << '\n';
void main()
	f(false);
	f(true);
	f(false);
	f(true);
The output being
123
123
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
  • · Replies 0 ·
10K
