Statics - I get a different angle than the solution manual who's wrong?
19 replies · 4K views
Femme_physics
The X axis in the first diagram is in line with the surface, but when you isolate BC it doesn't have to be. Notice how when we isolate BC our angles our different. Who's correct?
http://img192.imageshack.us/img192/236/objectthingy.jpg
The object is in static equilibrium.
Static Coeffecient between the box and surface: 0.3
Weight of box: 500 [N]
Measurements in mm
Joints are smooth pin.
Do the calculations as the box about to descend down the surface
Ignore the weight of lever ACCalculate:
Force at AB
The moment around C, acting on the arm BC
I got Fab correct (in the solution manual they call it "S"). However, we have our differences at beam BC about the angle, which I'd like you to help me resolve. The manual thinks it's 20 degrees, I think it's 50 degrees. Attached my attempt and the solution manual's.
Precisely what angle are you referring to?
Hi FP, :)
I'm afraid the angle of BC is unknown.
It seems to me that the problem statement is incomplete.
What you'd actually would need to do, is define a generic angle phi that BC makes, and calculate the moment as a function of phi, but it seems to me that it's as yet too early to do that.
In the drawing BC seems to be parallel to the ground, making the angle in your calculations correct! :)
The solution manual's "choice" makes BC parallel to the slope.
I'd recommend putting a note in your solution that you have "chosen" to take BC parallel to the ground in order to find a numeric solution.
http://img838.imageshack.us/img838/8595/anglez.jpg
Really? Are you sure? We're told the surface is 30 degrees from the ground, and that AB is 20 degrees from it. It appears clear to me it's 50 degrees! (20+30)
http://img171.imageshack.us/img171/7159/angle2p.jpg
Hmm, it's drawn and calculated though as though it's parallel to the ground!
But we have different numeric solutions, so someone must be wrong!
Yes, but there might be tiny angle of say 3 degrees and it would throw all your calculations off! :wink:
I find no fault in your trigonometry. :smile:
If you ask 2 people to slice a pie into 2 pieces, is it wrong if they come out with different sized pieces? :)
As long as they get the job done...
On a scientific note, it is good practice to write down any assumptions and choices you make!
But all the measurements are given to me, that's the exercise. It doesn't say anything about hidden degrees, and I never heard they exist. Have anyone ever seen those 3 degrees? I keep hearing stories about them, but where are they? Frankly I'm a 3 degrees atheist. Call me a sinner!
Wait wait wait, so far in all my calculations of static exercises (and I've solved tons, you've participated in some) I never had that you can get a different numerical result for using a different plane. Fab is the combined vector of its y and x components. But the combined vector must have a certain defined angle from the horizontal plane. Look at the solution manual, it draws a STRAIGHT LINE and still defines it at 20 degrees. But we agreed it's 50! I'm totally baffled.
I seem to remember a mechanics problem a little while ago, where you had neglected a *tiny* angle.
At the time thou claimeth that thou hath not seen it and did not know it existed.
I was pleased that you mended your ways, and became a firm believer in tiny angles (bringing you to the righteous answer of course).
Have your beliefs become so weak yet again? :smile:
[edit]In my job I had to revise the entire model being used once to take care of an angle of about 0.1 degrees.
However, the accuracy of the machine increased dramatically. :)[/edit]
I give in! :smile:
You are *right*.
The angle is 50 degrees and the solution manual is *wrong*.
I give it my *stamp of dogma approval*.
Haha, well 3 degrees atheist does mean 357 degrees believer. ;) I'd say I'm pretty righteous and deserve to get to math heaven where I'll have fun with 72 sexy mechanic problems ;)--------------
Are you referring to this exercise?https://www.physicsforums.com/showthread.php?t=470087
I give in!
You are *right*.
LOL
Wait wait, you can't just give in! So I was right all along? What about your previous arguments about 2 possible solutions depending on how you look at it? Were they false too?
LOL
I say, that's a very sexy mechanic problem ;)
But no, that was before my time.
I see you had other help at the time.
And what's this, are you a dwarf from Tolkien?
The one I meant is this one: https://www.physicsforums.com/showthread.php?t=490836
And now that you mention it, it's kind of sexy too :rolleyes:
They would combine perfectly! ;)
Nah, I am right! I'm always right!
(Aherm, ... unless of course I'm ... *cough* wrong *cough*)
Hehe... my nickname before this was "Dory"... I changed it, but I now regret having changed it :P Oh well.
Judging by the fact they're both hangers, I'd say it'll be kinda gay if they combine lol
But I remember that exercise well. Good call :)
AHA :D So wait, can I submit it as an official mistake the solution manual made?
I do have your coveted stamp of approval on the page it appears^^
Why the regret?
Good call :)
I think we need yet another mechanics problem!
Let me put it this way.
It's obvious to me that they made a mistake in the solution manual. They misjudged the angle and thought it was 20 degrees. I give my stamp of approval for saying that.
But if you would make that "mistake" yourself on an exam, I expect you could convince the teacher to allow it^^
Why the regret?
Because then I had an actual nickname, like an identity. Now the nick more general. Nevermind, I was just led to believe after a while that "Dory" is more of a male name, or a male dwarf name, so I went radically opposite. Oh well.
Plus, it hints that I know very well physics, while I'm more of a beginner. Well, beginner+, let's make it :)
One is never too far off :D
Gotcha!
Speaking of tiny wrong angles... my alpha in this question (11.537) IMO is more accurate than the solution manual's alpha (11.31). Can you confirm that?
Sorry, no.
Alpha is part of a triangle where the hypothenusa is as yet unknown.
The fraction of the other 2 sides corresponds to the tangens.
So alpha = arctan(0.2 / 4) which is what the solution manual says (as opposed to your alpha = arcsin(0.2 / 4) which is not true).
In your drawing the right angle on top is drawn like a little bit less than a right angle (just a tiny bit) making it easy to think that the other angle near the center of the sphere is a right angle.
But the hypotenuse is 2! I think.
I didn't do arcsin (0.2/4)
I did arcsin (0.4/2)!
Are you telling me that the hypotenuse is actually the length from A to the center of the circle? Hmm.. I now see in the manual's drawing that it is indeed not 90 degrees angle...
I'm not aware of any dwarf with the name Dory, the closest I know of is Torin.
And Dory appears to be a strictly female name.
You have shown yourself to be a true physics lover!
So that fits! :)
My own nick is a carry over from an old forum.
Every now and then I feel I should have picked a more physics like nick, but that's too late now.
Yes.
My mistake. I mixed the numbers up.
I meant arctan(0.4 / 2) which is arctan(0.2).
I like Serena said:
Yes.
I think I see it now, thanks :)
As long as I have you genius here, I'd like to milk it for as much as I can!
I know this is getting back to trigonometry but I seem to have an issue with angles in mechanics questions and I already started this thread so I'm just continuing it here.How are my calculations wrong in determining angle ADC equals 90? Visually it doesn't look like 90, but according to the numbers it does turn out 90!
http://img832.imageshack.us/img832/9943/trap1.jpg
http://img848.imageshack.us/img848/8400/trap2g.jpg
Not sure, I once played a paladin character in a fantasy role-playing online called "Dory" and someone sent me a PM thinking I'm a dwarf. Ugh.
So that fits! :)
Guess so! :)
Menne physics? :D
Always trust your visual queues!
And in case of doubt, make a drawing that is on scale and measure up what you want to know (that will also give you an acceptable answer!). And again: trust your visual queues!
In this case you have found AC=38.01 while AB=35.717
So the numbers say AC is longer than AB, but if you look to your drawing you'll find that AC is visually shorter than AB. The numbers must be wrong! How?
I think it's the first letter "D".
In fantasy games it's not uncommon to characterize your name with the first letter of the race. "Elory" would have been an elf! :)
Makes it easier to remember what kind of character you're playing this time.
Femme_physics said:
Menne physics? :D
:smile:
*TOOOOOOOOOOOT* (blowing the golden horn)
Cuz I'm stupid and I didn't see where's the hypotenuse. Thanks!
I just jumped on the diagonal one instead of looking for the length opposite to the 90 degrees. *smacks forehead 38.01 times*
In fantasy games it's not common to characterize your name with the first letter of the race. "Elory" would have been an elf! :)
This is great, trigonometric, mechanic, and role-playing advice all in one thread. This must what cyber-heaven feels like. No, no... it IS cyber-heaven! :D
LOL
