Statics - long rod of linear varying density supported at both ends
The discussion focuses on calculating the readings of two scales supporting a 3.0 m long rod with a linearly varying density defined by the equation ρ = a + bx, where a = 5.0 kg/m and b = 5.0 kg/m². To determine the scale readings, one must first calculate the total mass of the rod and its center of mass. The normal forces exerted by the scales can be found using the principles of net torque and the equilibrium condition of forces in the vertical direction.
  • Understanding of linear density functions
  • Knowledge of torque and equilibrium in statics
  • Familiarity with calculating center of mass
  • Basic principles of forces and normal force
  • Calculate the total mass of a rod with varying density
  • Learn how to find the center of mass for non-uniform objects
  • Study the application of torque in static equilibrium problems
  • Explore the relationship between normal force and weight distribution
Students and professionals in physics, particularly those studying statics and mechanics, as well as engineers dealing with structural analysis and load distribution.
jtulibarri
A 3.0 m long rod has a density described by = a + bx, where is the density in kilograms per meter of length, a = 5.0 kg/m, b = 5.0 kg/m2, and x is the distance in meters from the left end of the rod. The rod rests horizontally with its ends each supported by a scale. What do the two scales read?
I don't even know how to start this one.
If anyone can show me how to set this up I can solve the rest
First find the mass of the rod, and the location of the center of mass of the rod...
The measurement the scale reads, is the magnitude of the normal force that the scale exerts...
You can find one of these forces using net torque about the appropriate point = 0...
Then the other force can also be obtained using torque... or using sum of forces in y-direction = 0.
  • · Replies 19 ·
  • · Replies 29 ·
