Statistics: normal distribution
8 replies · 18K views
k77i
Suppose that X is normally distributed with mean 95 and standard deviation 17.
A. What is the probability that is greater than 126.79?
B. What value of X does only the top 16% exceed?
z= (X-(mean of x))/standard deviation
using the equation, I found z= (126.79-95)/17=1.87
then using a statistical table, the value for P(z greater than 1.87) = 1 - P(z=1.87) = 0.0307
But this is wrong..
For B)
I considered that 84% must be the value which the top 16% must exceed.. then 84% of 95 is 88.42
Also wrong (well I wasn't really too sure about part B)
Any help would be appreciated!
The tabular value for above that z-score seems correct. Your z-score seems correct to the given number of decimal places. How do you know that the answer under a) is "wrong"?
For B), you should find such a [itex]Z_{0}[/itex] that:
[tex] P(Z > Z_{0}) = 0.16 \Rightarrow P(Z < Z_{0}) = 0.84[/tex]
Using that value for [itex]Z_{0}[/itex], solve for X in the expression:
[tex] Z = \frac{X - \mu}{\sigma}[/tex]
where [itex]\mu[/itex] is the mean and [itex]\sigma[/itex] is the standard deviation.
But this is wrong..
No, that is correct. Why do you say it is wrong?
For B)
95 is the mean- 50% are larger than 95!
Looking at a table of the normal distribution, N(x< a)= 0.84 for a= 1.0 (approximately).
[tex]\frac{z- 95}{17}= 1.0[/tex]
solve for z.
Thank you both for the help with part B. As for part A, since its a webwork assignment, it tells me when I enter an incorrect answer. I guess it's possible that there might be some sort of problem with the webwork.
maybe you need to use the correct number of significant figures.
I put all the numbers (0.0307).. The chart I have for the z-score only goes upto 4 decimal places so I'm not sure how much it's actually supposed to go up to
Well, assuming the mean and the standard deviation are known to the same number of significant figures as 126.79, then the z-score is:
[tex] \frac{126.79 - 95}{17} = \frac{31.79}{17} = 1.870[/tex]
to 4 significant figures (actually the quotient is exact). For this, the probability in question is:
1 - 0.9693 = 0.0307
So, it can't be that.
Are you sure this is the standard deviation and not the variance?
Yes it is the standard deviation. I copied the question word for word..
In any case it's too late, the homework set is closed and apparently the accepted answer was 0307419079428789. I think I was supposed to use excel to find the exact value to the correct amount of significant figures..
