Statistics: paried observations
  • Thread starter Thread starter k77i
    Statistics
A discussion on calculating the 95.8% confidence interval for the mean difference in LDL levels before and after taking a cholesterol-lowering medication revealed discrepancies in statistical calculations. The initial attempt yielded a confidence interval of (-122.586, 162.586), which was identified as incorrect. A participant clarified that the correct sample mean difference was 20, with a sample standard deviation of 15.3695, leading to a revised confidence interval of (8.5, 31.5). The calculations were verified using both Maple and Excel, confirming the latter's accuracy. The conversation emphasizes the importance of correctly calculating the standard deviation of differences for accurate statistical analysis.
k77i
To test the efficacy of a new cholesterol-lowering medication, 10 people are selected at random. Each has their LDL levels measured (shown below as Before), then take the medicine for 10 weeks, and then has their LDL levels measured again (After).
Before After
195 175
131 129
141 105
182 184
173 138
123 120
147 115
156 144
125 87
161 137
Give a 95.8% confidence interval for meanB - meanA , the difference between LDL levels before and after taking the medication.
d(bar) - t(alpha/2)(Sd/sqrt(n)) < meanDifference < d(bar) + t(alpha/2)(Sd/sqrt(n))
I found all the values using excel:
d(bar) = 20
t(alpha/2) = 2.368676
Sd = 190.36
n = 10 (given)
and my answer was (-122.586 < meanDifference < 162.586)
but this is incorrect
Before After
195 175
131 129
141 105
182 184
173 138
123 120
147 115
156 144
125 87
161 137
d(bar) = 20
Sd = 190.36
n = 10 (given)
I don't know what your Sd is, but if it is the sample standard deviation of the difference, then it is wrong. I get sample mean difference = m = 20, sample standard dev. of diff. = s = 15.3695 (your Sd?). This gives a confidence interval very different from yours.
RGV
yes it was the standard deviation of the means and I don't get why it would be wrong, I used excel to calculate it..
Anyways the correct interval was (8.5,31.5)
I first used Maple to do the calculation. Then, to see if Excel was giving you the trouble, I re-did the analysis using Excel. It agreed with the Maple calculation and disagreed with yours. I suggest you search for a typo or something similar.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
  • · Replies 28 ·
  • · Replies 61 ·
12K
  • · Replies 125 ·
19K
