Steady State Flow out of a Tank Through a Vertical Pipe
The discussion revolves around fluid dynamics, specifically the steady state flow of fluid out of a tank through a vertical pipe. The original poster seeks to derive an expression for the height of fluid in the pipe (h2) based on known variables such as inflow rate (Qin), cross-sectional area (A), and gravitational acceleration (g). The context includes assumptions about atmospheric pressure at the pipe outlet and negligible friction.
  • Participants discuss the application of Torricelli's law and Bernoulli's equation, questioning the representation of height (h) in the context of the problem. There are attempts to clarify the relationship between h1 and h2, and the implications of pressure at various points in the system. Some participants express uncertainty about how to incorporate gravitational effects and the correct interpretation of pressure differences.
The discussion is active, with participants providing insights and asking clarifying questions. Some have suggested applying Bernoulli's equation at different points in the system, while others are exploring the implications of pressure and velocity in relation to the heights of fluid in the tank and pipe. There is a recognition of the need to clarify definitions and assumptions, but no explicit consensus has been reached.
Participants note the complexity of applying fluid dynamics principles to the scenario, particularly regarding the assumptions of zero friction and the atmospheric pressure condition. There is also mention of the original poster's limited background in fluid dynamics, which may influence the discussion's depth.
kartmaze
This is not homework, but something work-related. However, I will post it here since it's homework-relatable.
1. Homework Statement
Known variables: Qin , A (and obviously the diameter D of the pipe as well as g = 9.81 m/s2).
The pipe outlet and the top of the tank is at atmospheric pressure.
I want h1 to be as small as possible.
What I'm looking for is an expression for h2.
For the moment I'm assuming zero pipe friction.
2. Homework Equations
Torricelli's law (v is the same as U):
Q = U*A
Might be more?
In steady state, Qin and Qout are equal (=Q)
I tried solving for h using the two equations above and got
h = Q2 / (2*g*A2)
Is this h h1, h2, the sum of h1 and h2 or neither of these things?
Is this even the right way to approach this problem?
You used h in applying Torricelli's law. What does h need to represent for that law to apply?
Thanks for replying :)
I think h needs to represent the water level in a tank or equivalent, but it's the hole in the bottom of the pipe in my scenario (amongst other things) that confuses me. Are you implying that the pressure at the pipe outlet will be equal between this scenario and a scenario where the pipe oulet is clogged and Q = 0?
EDIT: When I think of it, my second sentence isn't relevant. When applying Torricelli's law, it's to the inlet of a pipe. So now I'm guessing that h in the equation is h1 . However, I'm not sure how to add the velocity that is driven by gravity (since the pipe is vertical and not horizontal).
(double post)
I'll try a different hint. At what points are the pressures known to be equal?
Let's apply Bernoulli's equation at 3 locations:
Point 1: The top of the fluid in the tank where the pressure is atmospheric Pa. If the datum for potential energy is at the outlet of the pipe, what is the ##\rho g h## at this location? What is the velocity at this location?
Point 2: The top of the outlet pipe, at h=h2. Call the pressure P at this location. What is the ##\rho g h## at this location? What is the velocity at this location?
Point 3: The outlet of the pipe. What is there pressure here? What is the ##\rho g h## here? What is the velocity at this location?
From this assessment, write out Bernoulli's equation for points 1 and 3, and then for points 2 and 3.
Thank your for your answers, both of you :)
My apologies for not understanding much of this. My fluid dynamics knowledge is almost zero, so I'm learning by "Googling" at the moment.
Point 1:
The velocity is zero. And the pressure is atmospheric, so we're only left with the potential energy part of the Bernoulli equation:
##g(h1+h2) = constant##
Point 2:
I think the pressure P at this loacation is ##\rho g h## which is ##\rho g h_1## . I also think the velocity at this location has to be the velocity in the pipe: ##Q / A##. Putting this into Bernoulli's equation I get:
##Q^2 / ( 2 A^2 ) + g h_2 + \rho g h_1 / \rho = constant##
which becomes
##Q^2 / ( 2 A^2 ) + g(h_1 + h_2) = constant##
This is where I think I have done something fundamentaly wrong somewhere, since solving for ponts 1 and 2 would give zero flow no matter what.
Point 3:
The velocity should be the same as in point 2, I think: ##Q / A##. I'm really unsure about the pressure here. I would guess it's atmospheric. However, ##\rho g h## is ##\rho g(h_1 + h_2)##.
When I got to this point in this post, I realized that I maybe shouldn't just insert ##\rho g h## in as P in Bernoulli's equation, but instead find an equation for the pressure difference between the two points. So I did that and got:
##P_3 = \rho ( g ( h_1 + h_2 ) - v^2 / 2)##
for both point 1 and 3, and 2 and 3.
If the pressure at P3 is atmospheric, I can set this to zero and get:
##h_2 = (v^2 / 2g) - h_1##
Am I on the right track here, or am I completely off?EDIT: I see now that I've changed the symbol for velocity from U to v. For clarification purposes, this is the same thing.
EDIT2: To my surprise, this is the exact equation from my original post if h1 is zero. So I guess, given that I'm on the right track, that the answer to my question regarding which h it is is the sum of h1 and h2. :)
Point 1:
Point 2:
which becomes
Point 3:
None of this was correct.
Point 1: ##p_a+\rho g (h_1+h_2)+0##
Point 2: ##P+\rho g h_1+\rho \frac{v^2}{2}##
Point 3: ##p_a+0+\rho \frac{v^2}{2}##
So, from Point 1 and Point 3, we have: ##p_a+\rho g (h_1+h_2)+0=p_a+0+\rho \frac{v^2}{2}## or $$v=\sqrt{2g(h_1+h_2)}\tag{1}$$
From Points 2 and 3 we have: ##P+\rho g h_1+\rho \frac{v^2}{2}=p_a+0+\rho \frac{v^2}{2}##. This gives:
$$P=p_a-\rho \frac{v^2}{2}$$
This equation indicates that the pressure at the very entrance to the tube is below atmospheric. So, the tube is sucking fluid out of the tank. That's why Eqn 1 has h_2 included in the total height of water responsible for the velocity.
Note that this analysis is valid as long as h1 is large compared to the diameter of the tube. If it is not, then the velocity at the upper surface is non-uniform (disturbed by the presence of the tube), and our equation for the upper surface is no longer valid.
Chet
Thank you so much for that comprehensive reply, Chet! :-)
That underpressure at point 2 is interesting. I did get the same expression for v as you though (Eqn 1), which I reorganized to an expression for h2, but my way there was a bit sketchy to say the least (and maybe just a fluke). When looking at your setup, things get a lot clearer. I've learned a lot, and I really appreciate your effort :-)
A good thing is also that you mentioned that this analysis only is valid when h1 is large compared to the tube diameter.
Thanks again.
