Stellar stream vs. Dark matter
  • Level: Graduate
  • Thread starter arabianights
9 replies · 1K views · last reply
arabianights
I attended a presentation held at an University in NYC last week, and the presenter (a physics PhD candidate) talked about the Stellar stream (interstellar structure caused by Galaxies gobbling each other), he spent big portion of time to link this observed phenomenon to dark matter and how observing the stellar stream can reveal the nature of dark matter. he also made a distinction of 'cold' vs. 'warm' dark matter.
I haven't been keeping the latest development on the dark matter, but somehow this seems fishy - how can one characters dark matter by stellar stream or call it 'warm' or 'cold', is this a consensus of view among modern astrophysicists?
Cold dark matter means that the average speed of dark matter particles is low (like baryonic matter), whereas hot dark matter particles typically move at large fractions of the speed of light. Since we don't have a firm grasp on what dark matter is, we don't know for certain which model (if either) is correct. I think the consensus view leans towards cold, but with significant dissent (including things like alternative gravity theories).
Stellar streams are new to me, but they seem to be streams of stars associated with galaxies but outside them, not part of their disc/ellipsoid structure. As such, I suspect they give you a way to probe the gravitational field outside the galaxy proper, which might tell you more about the dark matter distribution outside the main part of the galaxy. I would imagine that the warmer your dark matter is (the higher the typical speeds of particles) the more diffuse the dark matter halo of a galaxy is, and that would affect the speeds of stars in a stream. So studying them could tell you something about the nature of dark matter.
I think we should wait until Dark Matter is confirmed to exist in a lab before we start giving it attributes like "cold" or "hot."
We aren't giving it such attributes - yet. We're considering the possible cases where dark matter is made of relativistic or non-relativistic particles, or somewhere in between, working out the implications of each model, and seeing which (if any) case matches observation. This is the way science is supposed to work - if we're going to posit dark matter at all we need to consider its properties. For example, if we make two sets of observations on the same body we might find that one set rules out the hot dark matter model and the other rules out the cold dark matter model. Then we'd know we need to go back to the drawing board. You can't rule out any case if you refuse to consider it until it's found.
Theoretical models are important because they both interpret and predict observations.
One possibility is that dark matter consists of primordial black holes. In this case, it will never be, "confirmed to exist in a lab"
The Bullet Cluster (1E 0657-56) is a good playground to test it.
In that case, it seems that the "dark matter" (or anything that is causing the galaxy rotation curves) stays with the galaxies.
I think that relativistic particles wouldn't stay bound to the galaxies long enough to keep their rotation curves intact.
PBHs are highly constrained by observations though, you'd need a very fine-tuned mechanisms to produce them in the right mass windows. So, it's a bit dubious, but no more dubious than other candidates that try to fit our limited observations I suppose.
Which is the reason why the prevailing cosmological model is called Lambda-CDM, for Cold Dark Matter.
Agreed. My point was that there are some models that will never be detected in a lab. So this should not be the criterion for deciding if dark matter is "real".
