Stillness of Systems: Physics Laws & Double-Slit Experiment
  • Context: Graduate
  • Thread starter Thread starter StevieTNZ
    Systems
The discussion centers on the implications of stillness in physics, particularly in the context of the double-slit experiment and the Uncertainty Principle. Participants argue that while the double-slit experiment assumes ideal conditions—infinitely thin perfect absorbers and interference-free paths—real-world factors such as molecular vibration and air currents can distort results. The conversation highlights that stillness is one of many variables affecting experimental outcomes, and there is no universal equation governing stillness across all systems.
  • Understanding of the double-slit experiment
  • Familiarity with the Uncertainty Principle in quantum mechanics
  • Knowledge of ideal vs. non-ideal conditions in physics experiments
  • Basic concepts of wave-particle duality
  • Research the mathematical modeling of non-ideal conditions in quantum mechanics
  • Explore the implications of the Uncertainty Principle on experimental physics
  • Study the effects of environmental factors on quantum experiments
  • Investigate the concept of path integrals in quantum mechanics
Physics students, researchers in quantum mechanics, and anyone interested in the foundational principles of experimental physics and their real-world applications.
StevieTNZ
Hi there,
I'm not sure if I read somewhere - but if we see a system (macroscopic usually) and it looks still, is it actually not still? Is there a universal equation that governs how 'still' an object is?
In the double-slit experiment, if we have the slits not being still, because we're calculating the paths possible for the system to reach point B as if the slits are in a certain position - they're 'moving' - can we safely ignore any stillness issues in any Physics equation without affecting the accuracy of the Physics equations?
This question dates back quite a while, but am interested in knowing the answer.
Perhaps have a think about the implications of the Uncertainty principle. Prevents you knowing both the position and momentum at the same time. If the momentum is known (for example velocity = 0) then the position is unknown.
http://en.wikipedia.org/wiki/Uncertainty_principle
I'm not sure what the OP means by "safely ignore". Clearly this is a small scale effect that can be ignored in many situations.
The math for the double slit assumes infinitely thin perfect absorbers with perfect boundaries and interference free paths. To the extent that is not true, the results are distorted. The inherent vibration or uncertainty of the molecules at the boundaries and the resulting "non-ideal" interaction with the particle could be modeled. (but not by me)
So, stillness is but one of many factors that can effect experiments. I don't know of any universal treatment of stillness since it could be caused by uncertainty, vibration due to air currents, gravitational effects due to anything, or whatever.
What do you mean by thin perfect absorbers with perfect boundaries?
What do you mean by what do you mean by? (lol)
I think I know what you are asking, but I'm not sure how far I can take it. I'm just saying that the simplistic math assumes the slits and barriers are ideal. There is no reflection from internal surfaces of a thick barrier, that the boundaries are not jagged, and when the barrier is contacted it results in perfect absorption (and none if not contacted). In determining the area of the slit there are no angle of approach issues caused by barrier thickness. I think I should have added that the particle is dimensionless. After all, the path integral assumes the particle takes all possible paths and a thick barrier has effects on the possible paths.
  • · Replies 36 ·
  • · Replies 49 ·
  • · Replies 33 ·
  • · Replies 16 ·
  • · Replies 17 ·
