What is the correct way to use Stirling's approximation in this example?
  • Thread starter Thread starter leonne
    Approximation
Stirling's approximation is used to simplify calculations involving large factorials, such as determining the probability of getting exactly 500 heads when flipping 1000 coins. The key formula is N! ≈ N^N e^(-N) (2πN)^(1/2). In the example, the multiplicity is calculated as Ω(500) = 1000! / (500! * 500!), and using Stirling's approximation, it simplifies to Ω(500) = 2^1000 / (500π)^(1/2). The probability is then found to be P = Ω(500) / 2^1000 = 1 / (500π)^(1/2) ≈ 0.025. For large numbers, it's often easier to reduce the fraction as a whole rather than calculating the numerator and denominator separately.
leonne
I don't really understand how to use Stirling's approximation. here's an example
you flip 1000 coins, whts the probability of getting exactly 500 head and 500tails
N!=NNe-N(2pieN)1/2
wht they did was
21000 total number outcome
\Omega(500)=1000!/500!2 multiplicity
than used the Stirling's approximation to get this which I don't get how. What do I plug in for N
\Omega(500)=21000/(500pie)1/2
P=\Omega(500)/21000= 1/(500pie)1/2= .025
thanks
you divide the stirling approximation for N=1000 by the square of the stirling approximation for N=500. And it's Pi not pie silly
lol thanks,
so it would be 10001000e-1000(2pi1000)1/2/ (500500e-500(2pi500)1/2)2
yes and that simplifies to what you want
um I don't think that is right i keep getting overflow error.
nvm after typing it in wolfam alpha it worked but how would i do it on my calculator, o well lol
These are very big numbers. You might find it easier to reduce the fraction as a whole rather than work out the denominator and numerator separately.
AM
We're going to need a bigger calculator.
Not really. The expression reduces to:
\frac{\Omega(500)}{2^{1000}} = \frac{(2\pi *1000)^{1/2}}{2\pi*500} = \frac{1}{(500\pi)^{1/2}} = .025
AM
The Stirling's approximation you want to use for this is
\ln(n) \simeq n\ln(n) - n
This is applicable for n \gg 1. So, for your example
\omega = \frac{1000!}{500!500!}
Take the logarithm of both sides and we find
\omega = \ln(1000!) - 2\ln(500!)
Which, using Stirling's approximation, gives us
\omega = 1000\ln(1000) - 1000 - 2(500\ln(500) - 500)
At this point it is easy to find that \omega = 10^{300}
