Stokes' Theorem for Line Integrals on Closed Curves: A Problem Solution
The discussion revolves around applying Stokes' theorem to evaluate a line integral over a closed curve defined by the intersection of two surfaces. The integral is confirmed to be correct numerically, but the working process is scrutinized. The participants clarify that the integral should be evaluated over the surface defined by the intersection, which is a circle with a radius of sqrt(2). There is some confusion about the integration surface, but it is established that either surface can be used for Stokes' theorem. The final consensus affirms the approach taken was valid, emphasizing the importance of correctly identifying the surface of integration.
bigevil
Please help me to check whether I did the right working for this problem. Thanks. The numerical answer is correct but I'm not very sure if the working is correct also.
Find \int y dx + z dy + x dz over the closed curve C which is the intersection of the surfaces whose equations are x + y = 2 and x^2 + y^2 + z^2 = 2(x+y)
First, I note that the integral required is the line integral for F . dr where F = (y, z, x). Since the curve is closed, we can apply Stokes' theorem. By Stokes' theorem \int F . dr = \iint (curl F) \cdot \b{n} dA.
Curl F = (-1,-1,-1) after applying the cross product.
Then I sketch the surfaces on the x-y axis and pick out the normal vector n = \frac{1}{\sqrt{2}}(\b{i} + \b{j}). Also \iint dA = \pi r^2. Then the answer for the line integral is -2\sqrt{2}\pi
What surface, exactly, are you integrating over? You are told that the curve is the intersection of two surfaces. To use Stoke's theorem, you must integrate over the entire surface: both of the given surfaces.
It looks like bigevil is integrating over the plane. You don't have to integrate over both surfaces. Either one should give you the same answer. I'm a little confused at you deduced the radius of the circle. But other than that, it's fine.
Sorry Halls, the closed curve is the intersection of the two equations. That curve is closed and the surface it covers is a circle (of radius sqrt(2) I think) then I'm integrating over the plane.
I don't know how to describe it, but I deduced by imagining that the line slices the sphere given. (I drew the whole thing in the x-y plane, ie looking from the 'top' down.) The plane (y + x = 2) runs through the centre of the sphere. I got radius sqrt 2 for the radius of the closed surface.
Thanx Dick and Halls.
Yes, exactly. The plane cuts through the center of a sphere with radius sqrt(2). You can use Stokes over that surface. As you did so well.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 26 ·
