Storing light and using it to propel an object
  • Context: High School
  • Thread starter Thread starter J3J33J333
    Light
The discussion centers around the feasibility of storing light for propulsion purposes, particularly in the context of space travel. Participants explore theoretical concepts such as photon rockets and the implications of light as a fuel source, while also addressing the challenges associated with weight and energy storage in spacecraft.
  • Some participants question the possibility of storing large quantities of light for extended periods, suggesting that it may not be feasible.
  • Others propose the concept of a photon rocket as a theoretical means of propulsion, noting that a container of light would have mass related to its energy content.
  • A participant expresses doubt about the practicality of directly storing light, suggesting that a light generator might be a more viable approach.
  • One participant inquires about materials with low photon attenuation and good internal reflection, indicating interest in optical resonators.
  • Another participant discusses the rocket equation and the energy requirements for propulsion using photon exhaust, emphasizing the relationship between energy and mass in this context.
  • Concerns are raised about the kinetic nature of light and its dissipation, questioning the practicality of using stored light for propulsion.
Participants do not reach a consensus on the feasibility of storing light for propulsion. There are competing views on the practicality of using light as a fuel source, with some arguing against it while others explore theoretical frameworks.
Limitations include unresolved assumptions about the nature of light storage, the definitions of energy and mass in this context, and the practical implications of using photon rockets versus light generators.
J3J33J333
TL;DR
Using Light as spaceship fuel
Is it possible to store large quantities of light for extended periods of time? If so would it make any sense to use it to propel a spaceship because it doesn't weigh anything? I read that one of the biggest issues with getting to space is the weight of the fuel.
Science news on Phys.org
J3J33J333 said:
Summary: Using Light as spaceship fuel
no
no
true
Theoretically, one of the most efficient means of accelerating in emty space is a photon rocket:
https://en.wikipedia.org/wiki/Photon_rocket
Note that a container full of light would in fact have a mass related to its total energy content.
OK, guess I was wrong about it being a good means of propulsion. Directly "storing light" still makes no sense. Have a light GENERATOR, as you pointed out, is a different thing and not what I interpreted the OP as meaning.
phinds said:
OK, guess I was wrong about it being a good means of propulsion. Directly "storing light" still makes no sense. Have a light GENERATOR, as you pointed out, is a different thing and hot what I interpreted the OP as meaning.
You're right, I was basically wondering if anyone knew about materials that have seriously low photon attenuation with good internal reflection. The photon rocket does help a good chunk with what I'm trying to figure out
What can i look up to calculate the mass?
The mass, ##M##, of a box of light in the centre of momentum frame of the box is given by:
$$Mc^2 = E$$ where ##E## is the total energy of all the photons in the box.
Note that if you have only one photon, then there is no centre of momentum reference frame. And this invariant mass, ##M##, cannot be defined.
You might be interested in the work of Kerry Vahala, a former classmate and one of the smartest people I ever met. He can build small optical resonators with Q → 1011, similar to "whispering galleries" IIRC. They're not for bulk energy storage so much as metrology.
BTW, the materials are basically glass and such. Also, it doesn't take too long for light to bounce around a resonator 1011 times.
You can use the rocket equation to figure out the (theoretical) delta-V possible with pure photon exhaust by setting exhaust speed ##v_e## equal to ##c##, the speed of light in vacuum. A PeroK mentions, you can relate the corresponding propellant mass (e.g. the trapped photons or corresponding matter/anti-matter) with the energy "required" to fuel up the rocket for a particular mass ratio using ##E = mc^2##.
For instance, if you would like to know how much "photon energy" ##E_p## is needed for a particular ##\Delta v## for a spaceship with mass ##m_f## after the "burn", then the relationship can be derived to be ##E_p = m_f c^2 (e^{\Delta V / c} -1 )##. Propelling something to, say, 1% of ##c## would thus take around 900 TJ per kg of spaceship. Note that for high delta-V's you need to consider a relativistic rocket to find the actual "physical" speed after such a burn.
phinds said:
no
He's totally right and that "no" makes storing light in a bucket, to use later, a real non-starter, even with a very shiny bucket.
There's an arm waving objection to the whole notion and that is that light is an essentially kinetic form of energy which is being dissipated or absorbed all the time. Using mechanical kinetic energy for transport is pretty uncommon (apart from freewheeling down hill on your bike and your momentum taking you to nearly the top of the next hill). The Gyrobus was one of those rare examples.
Using a photon beam, on the other hand, is one of many contenders for long distance travel with high final speeds, after many years of the drive being switched on. But the photon beam has to be generated at the time it's used.
:oldlaugh:
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 17 ·
