Strain and Stress in Thin-Walled Hoops Under Pressure
  • Thread starter Thread starter Jony S
    Strain Stress
The discussion focuses on the analysis of stress and strain in thin-walled hoops subjected to internal pressure. The primary equation referenced is the hoop stress formula, σh = p d / (2 t), where "p" is the internal pressure, "d" is the diameter, and "t" is the thickness of the hoop. Participants explore the application of Hooke's law, specifically relating stress to strain using Young's modulus "E" and Poisson's ratio "ν". The final formula derived for strain is strain = PD/4tE * (2-ν), integrating both stress and material properties.
  • Understanding of hoop stress in thin-walled structures
  • Familiarity with Hooke's law and Young's modulus of elasticity
  • Knowledge of Poisson's ratio and its implications in material deformation
  • Basic grasp of strain-displacement relationships in mechanics
  • Study the derivation of the strain-displacement equation for thin-walled cylinders
  • Learn about the application of Poisson's ratio in different materials
  • Explore the 3D version of Hooke's law and its components
  • Investigate the effects of external pressure on hoop stress and strain
Mechanical engineers, materials scientists, and students studying structural mechanics who are interested in the behavior of thin-walled structures under pressure.
Jony S
Hi all, this isn't exactly homework, but it is nonetheless a problem I would like to solve, so here goes.
Consider a thin-walled ring/hoop with diameter "d" and thickness "t". I want to know the change of diameter "Δd" due to the stress caused by pressure "p" being applied in this hoop (from inside to outside).
So, EngineeringToolBox tells me that the stress in the hoop is σh = p d / (2 t)
Can I apply Hooke's law directly here ? knowing the young's modulus of elasticity "E" for my material, can I say that σh = E * strain, where strain = Δd/d ? if not, what is the relation between the stress calculated from the first formula, the strain, and "E" ?
Are you familiar with the 3D version of Hooke's law, which includes all the stress and strain components.
These concepts are fairly new to me so I'm not "familiar" with much. Are you talking about Poisson's ratio, i.e., the expansion/compression of the material in perpendicular directions ? so I would add this:
σh - v(σr+σz)= E * strain
Yes. This is one of the equations you would use. The other relationship is the strain-displacement equation for the hoop strain. Do you know that equation?
No.
Searched a bit more and found this:
https://nptel.ac.in/courses/Webcourse-contents/IIT-ROORKEE/strength of materials/lects & picts/image/lect16/lecture16.htm
In the end of the first part there is a formula for displacement. This appears to be the combination of the two equations that we already had, i.e., strain = deltaD/D, and
strain = PD/4tE * (2-v) (σr is zero and σz is σh/2 ?)
v and E are characteristics of the material so we have everything ?
edit: corrected some mistakes
Jony S said:
No.
Yes, that's what I get (assuming that the ##(2-\nu)## is in the numerator
Yes it is :)
Thanks for the help!
Jony S said:
Yes it is :)
No problem. Nicely done.
Extra question for clarification, the stress is the same (opposite signal) if the pressure is applied externally, right ? If the pressure is the same inside and outside the total stress has to be zero.
Yes. p is really the pressure difference between inside and outside. For a cylinder in atmospheric air, it's the gauge pressure inside.
  • · Replies 61 ·
13K
10K
