Strain Tensor Based on Clifford Algebra
  • Context: Graduate
  • Thread starter Thread starter Arash1950
The discussion focuses on the formulation of the strain tensor using Clifford algebra, specifically addressing the displacement gradient tensor H defined as H=grad u = u_{i,j} e_i ⊗ e_j. It is established that H can be decomposed into the infinitesimal strain tensor epsilon and the rigid body rotation tensor Omega. The infinitesimal strain tensor is correctly expressed as epsilon=(H+H^t)/2, while the discussion critiques the application of the Dirac operator D in generating the strain tensor, suggesting that a dyadic product H=D ⊗ u may be necessary for accurate representation.
  • Understanding of continuum mechanics and displacement fields
  • Familiarity with tensor algebra and tensor products
  • Knowledge of Clifford algebra and the Dirac operator
  • Basic principles of elasticity theory and strain tensors
  • Research the properties of the Dirac operator in Clifford analysis
  • Explore the application of dyadic products in tensor calculus
  • Study the relationship between curl and rigid body rotation in continuum mechanics
  • Investigate existing literature on strain tensor formulations in Clifford algebra
Researchers, mathematicians, and engineers specializing in continuum mechanics, elasticity theory, and advanced mathematical frameworks such as Clifford algebra.
Arash1950
Let u=u_i e_i be the displacement field of a continuum body. Then the displacement gradient tensor H based on classical formulation is given by H=grad u = u_{i,j} e_i \otimes e_j, where \otimes represents tensor product.H is decomposed intro two parts. Namely, H=epsilon+Omega. The infinitesimal strain tensor is given by epsilon=(H+H^t)/2, where H^t=transose(H). In component form, we have epsilon_{ij}=(u_{i,j}+u_{j,i})/2. On the other hand, Omega=(H-H^t)/2 describes the rigid body rotation during deformation.
In Clifford analysis, the gradient operator (known as the Dirac operator) is defined as D=e_i \partial / \partial x_i. The displacement gradient MAY be written as H=Du=D.u+D^u (I think this is incorrect).
The first term is indeed D.u=div u that describes the dilatation (volume change).The second term is similar to curl(u) that describes rigid body rotation [it is related to Omega. Basically curl(u) is twice the axial vector of Omega].
I have also seen relations of the form epsilon=(Du+uD)/2, which is absolutely incorrect. indeed (Du+uD)/2=div u=trace(epsilon)
It seems that the gradient operator in Clifford analysis cannot produce the strain tensor in elasticity. Probably, a dyadic product of the form H=D \otimes u is needed. But as far as I know, this product is not standard in Clifford analysis.
I have not seen any good relation in papers and books. Moreover, ChatGPT was not able to provide useful information.
My questions:
  • How to generate epsilon_{ij}=(u_{i,j}+u_{j,i})/2 based on the gradient operation in Clifford analysis?
  • What is the general definition of the Gradient operator in Clifford analysis? It seems that the Dirac operator "D", as mentioned above, does not work properly.
Can you please reformat your post to make it more readable? You can use double hash-marks (##) before and after your inline LaTeX expressions to render them. For more info, open the "LaTeX Guide" link at the bottom-left of the editing window.
For large deformations, the definition of the strain tensor is not unique. There are many tensorial forms at large deformation that reduce to the same infinitesimal strain tensor in the limit of small deformations. For example $$\boldsymbol \epsilon=\frac{1}{2}(\bf G-\bf I)$$where G is the product of the deformation gradient tensor with its transpose and I is the identity tensor.
Arash1950 said:
  • How to generate ##\epsilon_{ij}=(u_{i,j}+u_{j,i})/2## based on the gradient operation in Clifford analysis?
Is it clear Clifford algebra should be able too? Are symmetric matrices even in the algebra?
  • · Replies 30 ·
  • · Replies 0 ·
