Strange quadratic manipulation
6 replies · 3K views
shirozack
TL;DR
Why can y = ax^2 + bx +c be express as y = (a)(x - intercept1)(x - intercept2) ?
For example, let's say the quadratic curve ax^2 + bx + c intersects the x-axis at x=-5, x = 3
Why is it we can say the equation of the curve is then (a)(x+5)(x-3) ?
how does this manipulation come about, in particular, the (a) coefficient. Why can we just slot (a) into the factors (x+5)(x-3) ?
THanks!
Mathematics news on Phys.org
[tex]ax^2+bx+c=a(x-\alpha)(x-\beta)[/tex]
where
[tex]\alpha,\beta=\frac{-b\pm\sqrt{b^2-4ac}}{2a}[/tex]
You can confim it as
[tex]a(x-\alpha)(x-\beta)=a[x^2-(\alpha+\beta)x+\alpha\beta]=ax^2+bx+c[/tex]
by calculation.
quadratic equation
[tex]ax^2+bx+c=a(x-\alpha)(x-\beta)=0[/tex]
has solution
[tex]x=\alpha,\beta[/tex]
so crossing points of curve y=ax^2+bx+c and line y=0 is
[tex](\alpha,0)(\beta,0)[/tex]
shirozack said:
TL;DR Summary: Why can y = ax^2 + bx +c be express as y = (a)(x - intercept1)(x - intercept2) ?
THanks!
If you have any polynomial ##y(x)=a_nx^n+\ldots+a_1x+a_0## then we can perform a long division dividing it by ##x-c.## This results in an expression ##y(x)=q_1(x)\cdot (x-c) + r_1(x)## where the remainder polynomial has a degree of at most ##n-1## and ##q_1(x)=a_n.##
Now, if ##x=c## is an intersection point, i.e. ##0=y(c)## then $$0=y(c)=q_1(c)\cdot(c-c)+r_1(c)=q_1(c)\cdot 0+r_1(c)=r_1(c) .$$
This means, that the remainder is either zero or has an intersection point at ##x=c,## too. Now, we can do the same long division again for ##r_1(x)## and get an expression ##r_1(x)=q_2(x)\cdot(x-c)+r_2(x)## where the remainder polynomial has this time at most a degree of ##n-2## and
\begin{align*}
y(x)&=q_1(x)\cdot(x-c)+r_1(x)\\&=q_1(x)\cdot(x-c)+q_2(x)\cdot(x-c)+r_2(x)\\&=(q_1(x)+q_2(x))\cdot (x-c) +r_2(x).
\end{align*}
We proceed this algorithm of long divisions until ##r_m(x)=0.## Since the degree of the remainders shrinks with every step, this has to be the case at some point. In the end, we have an expression
y(x)=(q_1(x)+\ldots +q_m(x))\cdot (x-c) +0.
This proves, that if ##x=c## is an intersection point of the polynomial ##y(x)## then ##(x-c)\,|\,y(x).##
The other direction is easy: if ##(x-c)\,|\,y(x)## then ##y(x)=q(x)\cdot (x-c)## and ##y(c)=0.## Together, we have shown that ##x=c## is an intersection point of ##y(x)## if and only if ##(x-c)## divides ##y(x).##
There are, however, polynomials like for example ##y(x)=x^2+1## that do not have real intersection points at all. Those polynomials only split over the complex numbers: ##x^2+1=(x+\boldsymbol i)(x- \boldsymbol i).##
Finally, here is an example how long division for polynomials is done:
https://www.physicsforums.com/threa...r-a-polynomial-over-z-z3.889140/#post-5595083
where
by calculation.
quadratic equation
has solution
so b is -a(α+β)
and c is aαβ ?
THanks!
Here's another way to look at it.
Suppose ##p(x) = x^2 + bx + c## has a y-intercept at ##x = \alpha##. Note that ##p(\alpha) = 0##.
Let ##z = x - \alpha##, then:
$$p(x) = p(z+ \alpha) = (z + \alpha)^2 + b(z + \alpha) + c = z^2 + (2\alpha + b)z + \alpha^2 + b\alpha + c$$Now, we know that ##\alpha^2 + b\alpha + c = p(\alpha) = 0##. So:
$$p(x) = z^2 + (2\alpha + b)z = z(z + 2\alpha + b) = (x - \alpha)(x + \alpha + b)$$And, we see that ##p(x) = 0## when ##x = -\alpha - b##. That gives us a second y-intercept. Let's call this ##\beta = -\alpha - b##. This completes the factorisation:
$$p(x) = (x - \alpha)(x - \beta)$$Where ##\alpha, \beta## are the y-intercepts. Note that it's possible, of course, that ##\alpha = \beta##. That happens when ##\alpha = -\frac b 2##.
Finally, we consider the general quadratic
$$p(x) = ax^2 + bx + c = a(x^2 + \frac b a x + \frac c a) = a(x- \alpha)(x - \beta)$$Where ##\alpha, \beta## are the y-interecpts of the quadratic ##x^2 + \frac b a x + \frac c a##. But, this has precisely the same y-intercepts as ##p(x)##. One quadratic is just a scalar multiple of the other. Hence ##\alpha, \beta## are also the y-intercepts of ##p(x)##. QED
Given the values of a quadratic polynomial, ##ax^2+bx+c##, at three points ##x_0,x_1##, and ##x_2##, which are ##y_0,y_1##, and ##y_2## respectively, you can construct a quadratic polynomial ##p(x)## that matches these values as follows:
\begin{align*}
p(x) = y_0 \frac{x-x_1}{x_0-x_1} \frac{x-x_2}{x_0-x_2} + y_1 \frac{x-x_0}{x_1-x_0} \frac{x-x_2}{x_1-x_2} + y_2 \frac{x-x_0}{x_2-x_0} \frac{x-x_1}{x_2-x_1} \qquad (1)
\end{align*}
This quadratic polynomial ##p(x)## uniquely fits the given values: ##p(x_0)=y_0 , p(x_1) = y_1##, and ##p(x_2)=y_2##. To show its uniqueness, assume there is another quadratic polynomial ##\tilde{p}(x)## that also fits these values. Consider the difference ##q(x)=p(x) - \tilde{p}(x)##. This difference ##q(x)## is a quadratic polynomial:
\begin{align*}
q(x) = p (x) - \tilde{p} (x) = ex^2+fx+g
\end{align*}
which has the three distinct real roots ##x_0,x_1,x_2##. This implies that ##q(x)## is actually the zero polynomial - i.e. ##e=f=g=0##. To understand why, note that as ##q(x)## has three distinct real roots, it would have a shape with both a minimum and a maximum, as illustrated in the graph.
At the minimum and a maximum the derivative ##q' (x)## vanishes. However, the derivative of ##q(x)##, which is ##q'(x) = 2ex + f##, can only have one root. Therefore, it cannot provide the necessary two critical points for ##q(x)## to have both a minimum and a maximum. This contradiction implies that ##q(x)## must be identically zero, and that ##\tilde{p}(x)=p(x)##.
Now let us assume that ##p(x)## has two distinct real roots: ##x_1## and ##x_2##. Then ##y_1=0## and ##y_2=0## and using this in Eq. (1):
\begin{align*}
p(x) = y_0 \frac{x-x_1}{x_0-x_1} \frac{x-x_2}{x_0-x_2} = \frac{y_0}{(x_0-x_1)(x_0-x_2)} (x-x_1)(x-x_2)
\end{align*}
As we have shown that the quadratic polynomial is unique, and we know it is given by ##ax^2+bx+c##, we have ##a=\frac{y_0}{(x_0-x_1)(x_0-x_2)}##, and so:
\begin{align*}
p(x) = a (x-x_1)(x-x_2) .
\end{align*}
