Simple manipulation of x^2 - 1 = 0, getting x=0 as a solution.
  • Level: High School
  • Thread starter Thread starter malignant
    Manipulation
42 replies · 7K views
micromass said:
The expression 0/0 is undefined. The expression
[tex]\frac{x^2 -1}{x^2 - 1}[/tex]
is therefore undefined for all ##x## which make the denominator ##0##.
0/0=1 may be undefined but (x^2 - 1) / (x^2 - 1) when x=(-1, 1) proves it.
P.j.S .
Mathematics news on Phys.org
P.j.S .
If ##x=1##, then
[tex]\frac{x^2-1}{x^2 -1}[/tex]
is undefined. Same with ##x=-1##.
micromass said:
If ##x=1##, then
(x^2 - 1) / (x^2 - 1) = 1 is that true or false?
micromass said:
Depends on the value of ##x##.
Something divided by itself always = 1. x^2 - 1 is no different.
Therefore for example when x=1 then 0/0=1:
(x^2 - 1) / (x^2 - 1) = 1. This may be undefined but it is proved true by the fundamental mentioned above.
Prove that 0 / 0 = 1 is not true.
Not true.
It's essentially a definition. The division "x/y" is defined for all real (and complex numbers) except for y=0. We have left "x/0" undefined by definition.
The reason is simple. What would we define it as?? You could argue that
[tex]\frac{x^2 - 1}{x^2 - 1}=1[/tex]
for all ##x## except ##1## and ##-1##. So you could say that it makes sense to let this equality hold also for ##1## and ##-1##. That way, we could define ##0/0=1##.
The reason we don't do this, is because we could also argue that for ##x\notin \{1,-1\}## that
[tex]\frac{2(x^2-1)}{x^2-1}=2[/tex]
So we want this to hold also for ##1## and ##-1##. But that forces ##0/0=2##.
In the same way, we could make a perfectly fine argument that ##0/0=r## for any number r! So there is no definition of ##0/0## which unambiguously extends the laws of arithmetic. This is why we define ##0/0## to be undefined.
micromass said:
Not true.
What is your answer for 2(x^2 - 1) / (x^2 - 1) = ?
It is undefined for ##x=1## and ##x=-1##. It is ##2## otherwise.
2(x^2 - 1) / (x^2 - 1) = x^2 - 1 if x=5 then the answer is 24. If x=1 then the answer = 0. Please show how you got the answer of 2.
For all real numbers x except 0, we have x/x=1. This implies that for all real numbers x except 1 and -1, we have
$$\frac{2(x^2-1)}{(x^2-1)}=2\cdot 1=2.$$
Wut?
So you are trying to teach me that 2(3)/3 = 2*1?
Yes, because what you said in post #39 implies that it's not.
2(x^2 - 1) = x^4 - 2x^2 + 1
This is wrong, but now at least I understand what you're doing wrong. ##2(x^2-1)## doesn't mean what you think it does. It's just the number 2 times the result of ##x^2-1##. It doesn't mean the same thing as ##(x^2-1)^2##.
Thank-you for pointing out my oversight.
