Strange thing i noticed about centroid of a cone vs triangle
The centroid of a cone is located at a height of h/4 from its base, where h represents the cone's height. This contrasts with the centroid of a triangle, which is positioned at h/3 from its base. When the cone is sliced into halves or quarter cones, the centroid remains consistently at h/4. The phenomenon occurs because rotating a right triangle to form a cone alters the centroid's position, demonstrating that the centroid of a solid generated by rotation differs from that of its 2D counterpart.
  • Understanding of calculus principles related to centroids
  • Familiarity with geometric shapes, specifically cones and triangles
  • Knowledge of centroid calculations for 2D and 3D shapes
  • Basic concepts of solid geometry and rotational solids
  • Study the derivation of centroids for various geometric shapes
  • Explore the relationship between 2D shapes and their 3D counterparts in terms of centroid positioning
  • Learn about the calculus of solids of revolution, focusing on techniques for finding centroids
  • Investigate the centroid properties of pyramids and other polyhedra
Mathematicians, engineering students, educators in geometry, and anyone interested in the properties of centroids in geometric shapes.
bhh1988
To calculate the centroid of a cone, it seems that you have to use calculus. It comes out to be h/4, where h is the height from the base of the cone. But intuitively I thought that the centroid would have been h/3 because that's a triangle's centroid, and the cone can be obtained by rotating a triangle.
Now notice that if you slice the cone in half so that you have two halves with semi-circle bases, the height of the centroid of each half should still be h/4. Now if you slice in half again so that you have quarter cones, the height of the centroid of each of the quarter cones will be h/4 again. You can continue slicing this way until you have virtually an infinite number of fraction cones, each with their bases being a tiny slice of a circle. Each of these should have their centroid height be h/4
You can also obtain one of these cone slices by taking a right triangle and rotating it by a tiny angle theta. But the triangle's centroid itself is h/3. So the moment you rotate it a little bit the centroid of the solid generated jumps down to h/4.
I'm not too sure what I'm asking here, but I just find this "jump" to be strange and am looking for some intuition as to why this happens. Can anyone explain?
I realize now that there shouldn't really be any more of a reason to get stuck on this as there is to get stuck on why the centroid of a pyramid is h/4 from the base while a triangle is h/3. The fractional cone as theta goes to 0 basically becomes a pyramid.
I think I'm satisfied enough with this reason now. It's not any more weird that the centroid of a triangle drops to h/4 the moment I rotate than it is weird that the centroid of a pyramid is h/4. But if anyone else has any other insights, please post.
  • · Replies 30 ·
