What determines the strength of a magnetic field in a cyclotron?
  • Context: Graduate
  • Thread starter Thread starter Aidan Davis
    Magnets Strength
The strength of a magnetic field in a cyclotron is determined by the uniform magnetic field created by two cylindrical permanent magnets, positioned with opposite poles facing each other. The magnetic flux density can be calculated using the formula for a long solenoid, which considers parameters such as radius, height, separation distance, material, and temperature. The particle acceleration occurs at the midpoint between the magnets, and while the discussion suggests the use of air cores, it also raises the possibility of using solenoidal electromagnets for adjustable flux density. This flexibility could enhance particle energy optimization.
  • Understanding of magnetic field concepts in physics
  • Familiarity with cyclotron design and operation
  • Knowledge of solenoid magnetic field calculations
  • Basic principles of electromagnetism
  • Research the formula for magnetic flux density in solenoids
  • Explore the design and functionality of solenoidal electromagnets
  • Investigate the differences between permanent magnets and electromagnets in cyclotron applications
  • Study the impact of temperature and material on magnetic field strength
Physicists, engineers, and students involved in particle acceleration, cyclotron design, and magnetic field optimization will benefit from this discussion.
Aidan Davis
In a cyclotron, I understand that a uniform magnetic field is used, oriented perpendicular to the plane in which the particles accelerate. This field is created by two cylindrical permanent magnets whose opposite poles face each other,as I understand it. What formula(e) determine the strength (flux density) of the field, based on parameters such as radius, height, separation distance, material, and temperature. The plane of acceleration for the particles is assumed to be the halfway point between the two magnets.
I could not find a full concise answer for this online, and since I have few resources outside of that, this is my go to when google fails. Thanks for the help.
I believe you can use simply the formula for long solenoid, supposing that the particle beam fits between 2 turns of the wire somewhere in the middle. The gap is probably as thin as possible, and obviously there is no material in it.
I'm not sure if the coils have ferrite or air cores (seems to have air cores), or if the magnets are actually straight or toroids. A few minutes of Googling didn't find it but the information should be out there somewhere...
Ah, a solenoidal electromagnet could be used as opposed to permanent magnets, as it would, through variations in current, allow for adjustments in the flux density in the field to give optimum particle energy.
Does a cyclotron like this exist or do they all have permanent magnets?
  • · Replies 198 ·
15K
  • · Replies 24 ·
  • · Replies 42 ·
  • · Replies 43 ·
