Strength of materials- simple truss problem
2 replies · 7K views · last reply
Jeff231
The bars in the truss each have a cross sectional area of 1.2in^2. If the maximum axial stress in any bar is not to exceed 25ksi, determine the maximum magnitude of P of the loads that can be applied to the truss. Determine the elongation of each member.
E=29,000 ksi
Flickr placeholder image reading "This photo is no longer available" with a broken-image icon, so no truss diagram is visible.
[tex] \sigma[/tex] = E* [tex]\epsilon[/tex]
[tex]\sigma[/tex] = P/A
[tex]\epsilon[/tex] = [tex]\delta[/tex] / L
Having trouble with Latex, but the top equation should read:
sigma=E*epsilon
the other two equations are stress=force/area and strain=elongation/lenth.
I got an answer, but I'm not sure if it's correct and if I'm solving this correctly.
Since I know [tex]\sigma[/tex]=25ksi, and E=29,000 ksi I used [tex]\sigma[/tex]=P/A solving for P, P= [tex]\sigma[/tex]A=(25ksi)(1.2in^2)=30 kip.
I assumed this to be Pmax.
Using [tex]\sigma[/tex]=E*epsilon I solved for epsilon. epsilon= [tex]\sigma[/tex]/E=25ksi/29000ksi = 8.62E-4.
Then used epsilon=delta/L. Solved for elongation, delta. delta=epsilon*L.
Then I just used plugged in my solved value of epsilon, and then the length of each bar.
Here's an example for AC: delta=epsilon*L=(8.62E-4)(4ft)(12in/1ft)=0.0414in.
I'm not sure if this correct since it would mean every bar that is the same length would have the same elongation. Is this correct? Or do I need to solve the system for the forces and then do something? I'm confused. Thank you for the help.
Axial stress is generated by a force perpendicular to the cross section, what is the direction of P in the diagram ?
Can you determine the force in each member of the truss, as a function of P?
