Stress and strain in a component with circular and square sections under 5kN compression
21 replies · 8K views
stackemup
The component shown in Fig 1 is made from a material with the following properties and is subjected to a compressive force of 5kN.
Material Properties :
Young’s Modulus of Elasticity – 200 GNm-2
Modulus of Rigidity – 90 GNm-2
Poisons ratio – 0.32
Calculate :
(a) The stress in :
(i) the circular section
(ii) the square section
(b) The strain in :
(i) The circular section
(ii) The square section
(c) The change in length of the component
(d) The change in diameter of the circular section
(e) The change in the 40mm dimension on the square section
(f) If the same component were subjected to a shear force of 7 kN as shown in FIG 2, calculate the shear strain in :
unsure
I have not made any attempt as of yet as I have not done this in a long time and need to be pointed in the right direction. I nwould greatly appreciate anyone who has the time, to take me through each question and guide me in the right direction. I am not asking for answers but for guidance on formulas to use and a bit of an explanation why each formula needs to be used. Thanks in advance.
Sorry, but PF is not a tutoring service. The rules state that you should at least make an attempt at a solution in order to receive help. You must have gotten this problem from some text or other source. Check that source for a discussion of basic concepts like stress and strain.
Thanks for the info ... I will attempt and answer and post it.
I have made an attempt on (a) but I am assuming it needs revising and quite a bit of work putting into it, but I would appreciate it if someone could help.
(a) The Stress in:
Stress = F / A
Area of cylinder = 2TTr^2 + h(2TTr)
= 7068.59 x 10^-3 m2
Force on cylinder
= 5 x 10^3
Stress
= 5 x 10^3 / 7068.59
= 707.3546
Area of square section = 1600 + 1600 + 2400 + 2400 + 2400 + 2400
= 12800 x 10^-3 m2
Force in square section
= 5 x 10^3
Stress
= 5 x 10^3 / 12800
= 0.390625
(a) The Stress in:
Stress = F / A
The area used for calculating stress is not the surface area of the cylinder but the cross-sectional area.
Force on cylinder
= 5 x 10^3
Stress
= 707.3546
= 12800 x 10^-3 m2
= 5 x 10^3
Stress
= 5 x 10^3 / 12800
= 0.390625
The area used for calculating stress is not the surface area of the block but the cross-sectional area.
The force is not being applied over the entire surface of the items but only on one particular portion of the part.
Are the dimensions in millimeters ? Check your area calculations !
Heres my revised attempt -
CSA = TTr^2
= 706.8583 x 10^-3 m2
Force on cylinder
= 5 x 10^3
Stress
= 5 x 10^3 / 706.8583
= 7.0736
CSA = 1600 x 10^-3 m2
Force on square section
= 5 x 10^3
Stress
= 5 x 10^3 / 1600
= 3.125
CSA = TTr^2
Force on cylinder
= 5 x 10^3
Stress
= 7.0736
= 5 x 10^3
Stress
= 5 x 10^3 / 1600
= 3.125
You're getting closer. You should always indicate the units on all calculation results.
The unit of stress in SI is the pascal. 1 pascal = 1 Newton / m2
You must be careful with the units for your area calculations. Although 1 meter = 1000 millimeters, 1 sq. meter ≠ 1000 sq. mm. Do you see why?
How does this look?
(a) The Stress in:
Stress = F / A
CSA = TTr^2
Radius = 15 x 10^-3 m
CSA = 0.000707 m2
Force on cylinder
= 5 x 10^3 N
Stress
= 5 x 10^3 / 0.000707
= - 7.073553 Pa
= 5 x 10^3 N
Stress
= 5 x 10^3 / 1.6 m2
= - 3.125 Pa
Am I correct in thinking that compressive stresses are defined as negative in sign?
stackemup said:
How does this look?
(a) The Stress in:
Stress = F / A
CSA = TTr^2
CSA = 0.000707 m2
Force on cylinder
= 5 x 10^3 N
Stress
= - 7.073553 Pa
Check your arithmetic here.
= 5 x 10^3 N
Stress
= 5 x 10^3 / 1.6 m2
= - 3.125 Pa
Check your arithmetic here. You are also using the wrong value for the CSA.
Yes, but that's a minor detail. It's more important to check your work to eliminate careless arithmetic mistakes or mistakes in copying numbers.
(a) The Stress in:
Stress = F / A
CSA = TTr^2
CSA = 0.000707 m2
Force on cylinder
= 5 x 10^3 N
Stress
= - 7.073553 MPa
CSA = 1600 x 10^-6 m2
= 5 x 10^3 N
Stress
= 5 x 10^3 / 0.0016 m2
= - 3.125 MPa
I have also attempted part B below.
(b) The strain in:
ε = dl / lo
= σ / E
= Stress / Young’s Modulus
Strain = 7.073553 / 200GNm
Strain = 3.53678 x 10^-8
Strain = 3.125 / 200GNm
Strain = 1.56250 x 10^-8
stackemup said:
(a) The Stress in:
Stress = F / A
CSA = TTr^2
CSA = 0.000707 m2
Force on cylinder
= 5 x 10^3 N
Stress
= 7.073553 MPa
= 5 x 10^3 N
Stress
= 3.125 MPa
(b) The strain in:
ε = dl / lo
= σ / E
For Part a), the stresses look good.
For Part b), you've backslid. The stresses you calculated are in units of MPa, not Pa. Also, Young's modulus is in units of GPa or GN/m2, not GNm. You've got to use the correct values of the stress to calculate correct values of the strain. You've got to be vigilant about making these silly mistakes.
This should now be correct -
(b) The strain in:
ε = dl / lo
= σ / E
Strain = 7.073553 / 200GN/m2
Strain = 0.0353678
Strain = 3.125 / 200GN/m2
Strain = 0.0156250
Thanks for the advice.
Not there yet! 7.07 MPa / 200 GPa is not 0.035. Same for (ii)
Thanks for the support.
I am struggling to calculate part (d) The change in diameter of the circular section.
Is the below formula used to calculate this?
Change in diameter = - original diameter x Poisons ratio x (change in length / original length)
Think of something you expect to remain constant. Diameter x length would remain constant with your formula. Would that be logical ?
My equation now doesn't seem correct.
I'm struggling to make any progress with this question.
I believe the lateral strain multiplied by the diameter gives the increase in diameter.
The lateral strain is obtained from poissons ration, and the positive sign determines an increase in lateral dimensions, which is expected when an object is under compression.
Sorry, I completely misread your post #15. Says transverse strain = - Poisson's ratio times axial stress/Young modulus , which is completely correct. My post #16 is wrong and distracting.
o:)
Yes ! Apart from the typo: 0.1131
And the diameter was 30 mm, not 60.
