Stress in Beams - Same Force, Same Area, Different Lengths
  • Level: Undergrad
  • Thread starter Victor.wong
    Beam Stress
6 replies · 4K views · last reply
Victor.wong
if you look at the attached photo.
we have 2 beams, 1) is shorter, 2) is longer. cross-sectional area is the same. same force is applied X cm from the fixed end.
what is the max stress in each case? why are they the same ( and why not)?
Take gravity out of the equation.
FEA shows different result.
  • Two hand-drawn sketches of cantilever beams fixed at the top, labelled 1 and 2. Each shows a 10 N force applied at the free end, with a distance labelled x cm from the fixed support, and the beam in 2 is longer than the beam in 1.
victor.wong
Hello victor, is this a lab experiment you are writing up?
You surely don't need a finite element analysis to distinguish between types of stress, this is more fundamental than FEA.
So what do you mean by max stress?
Do you know how to derive stress as a function of distance?
How different is "different"? Beam theory is only an approximation. A 3-D finite element model is a different approximation. You wouldn't expect them to be "exactly" the same.
I know it is a very simple question. but FEA is telling me sth i don't expect. so ask this equation and see who can explain.
first of all, stress only caused if a block of material is under 2 force. action force and reaction (the fixture). since the length under the point of force of action is not under another reaction force. these length should not affect the stress produced by this action force
in both cases, max stress appeared at the area around the top fixing point. if i let the applied force and location constant, changing the length of the block will change the max stress at the fixing area. why??
Well what do you mean by max stress?
Or if you like, what type of stress?
And how about answering my other questions, they were intended to help.
OK. may be a pic will explain more
if you see the new attachment, my question is, why is the length of the block below the applied force affect the stress at the circled area.
my thinking behind is, no matter how long the rod is below the force application. it should not affect the portion on top of the applied force.
right? and why?
  • Von Mises stress contour plot in MPa of a tall rectangular bar fixed at the bottom, colour scale 0.01 to 64.8 MPa, with the top region circled in red.
Do you know the difference between bending stress and shear stress?
