Stresses and change in length in a compound bar
  • Thread starter Thread starter paste
    Change Length
The discussion revolves around determining the stresses and change in length of a compound bar subjected to a compressive load. The materials involved are mild steel and concrete, with specific properties provided for each material, including Young's modulus and cross-sectional area.
  • Participants discuss calculations related to stress and strain for each material, questioning the next steps to find the overall change in length of the compound bar. Some participants reference effective spring constants and relationships between force, stress, and strain.
There is ongoing exploration of the relationships between the materials' properties and the overall behavior of the compound bar under load. Some participants have offered insights into the effective spring constants and how they relate to the change in length, while others seek clarification on specific terms and concepts.
Participants are navigating through the complexities of composite material behavior under load, with some uncertainty regarding the implications of their calculations and the definitions of certain terms like spring constants.
paste
Determine the stresses and the change in length of the compound bar.
compressive load F = 40kN
Length L = 0.25m
material (a) mild steel E = 205 GPa
material (a) area = 0.04m^2
material (b) concrete E = 10 GPa
material (b) area = 0.16m^2
For a similar example see example 2 of this PDF:
http://fetweb.ju.edu.jo/staff/che/ymubarak/Strength-lectures/chapter2.pdf
My calculations so far are:
(a) σ = 40/0.04 = 1000kNm^2
(b) σ = 40/0.16 = 250kNm^2
E=σ/ε → ε=σ/E
(a) ε = 1000*10^3/205*10^9
= 4.9*10^-6
(b) ε = 250*10^3/10*10^9
= 25*10^-6
Free change in length = ΔL = ε*L
(a) ΔL = 4.9*10^-6*0.25
= 1.2*10^-6m
(b) ΔL = 25*10^-680.25
= 6.25*10^-6m
After those calculations I am unsure what to do next to find the change in length in a joined compound bar.
See PDF
See above
Thanks a lot for any help in improving my understanding of this.
Does the following help? I think you have figured out what I call k1 and k2.
I forgot the following,
It may be related but I can't deduce anything from it.
Can anybody else offer a solution?
Young's modulus, Y = Stress/Strain = (F/A)/(ΔL/L)
So F = (Y*A*ΔL)/L = kΔL which is the relationship between the applied force on a "spring" and the distance it compresses. In your problem both the steel and concrete are compressed the same distance, they each have an effective spring constant for the problem as stated. So in your case you know k_steel and k_concrete as given above so,
ΔL = F/(k_steel + k_concrete)
Good luck!
Good luck!
After another reading of your link it probably makes sense that the concrete is under compression and the steel is under tension which is a common configuration of those materials, so in that case,
F = k_steel*ΔL_steel = - k_concrete*ΔL_concrete
the concrete gets shorter and the steel gets longer.
Thanks a lot for the replies spinnor, what is it that you are referring to with k btw? is it the Young's Modulus of the materials? concrete E = 10 GPa and mild steel E = 205 GPa
Thanks a lot again
  • · Replies 22 ·
