- 29,956
- 21,833
KipIngram said:Alternatively, we could have Bob going in a (very, very) large circle around Alice. Then the distance won't change at all, and what we'll be reducing to negligibility will be the change in Bob's direction of motion during that small bit of time. We can make his path approximate a straight line as closely as we wish.
Let me try a different approach. First we have Einstein's theory of Special Relativity. This is based on:
1) Velocity-based time dilation
2) Length Contraction
3) Relativity of simultaneity
4) (1) - (3) can all be bundled into the Lorentz transformation.
These can all be deduced from the invariance of the speed of light. This theory can be shown to be self-constistent. I.e. (1)-(4) form a consistent set of rules. Note that (1) - (4) apply for inertial reference frames.
Then we have an alternative theory, which I'll call Ingram's theory of Special Relativity. This is based on:
This theory is, fairly obviously, not self consistent. You can get some simple physical paradoxes based on a pair of moving clocks; and, you can also get some complicated physical paradoxes, based on cameras and observers, and light rays traveling across a large distance. As you have shown.
If you are asking whether your theory of special relativity is inconsistent, then I agree it is.
I say this because you only seem to accept time dilation, on its own. And not the other consequences of Einstein's theory.
On a second point, if Bob is moving in a circle, then he is accelerating (or repeatedly changing direction - at each marker, say). Then his rest frame is not a single inertial reference frame, and he cannot apply the rules of SR directly, as Alice or any inertial observer can.
For cicular motion the time dilation is asymmetric and Bob's clock will definitely lose time compared to any of Alice's that he passes. If his clock and the first of Alice's are synchronised, then when Bob returns to that clock after one full revolution, his clock will read 0.85 units and Alices's clock will read 1 unit.
In conclusion, there are literally dozens of previous threads on PF, based on the same misconceptions:
1) Time dilation is all there is.
and/or
2) Motion in a very large circle is the same as linear inertial motion.
