Struggling with the rules behind electricity
  • Thread starter Thread starter Kuzon
    Electricity Rules
The discussion centers on the behavior of charged particles in electric fields, specifically addressing a scenario where a particle's kinetic energy decreases from 9480 eV to 8260 eV while moving from a potential of -43.0 V to +25.0 V. The charge of the particle is determined to be positive, as it loses kinetic energy when moving from a lower to a higher electric potential. This contradicts the common understanding that negative charges flow from low to high voltage, highlighting the importance of understanding the role of electric fields in determining the direction of force on charges.
  • Understanding of electric potential and voltage
  • Familiarity with the concept of kinetic energy in physics
  • Knowledge of the relationship between charge, electric field, and force
  • Basic algebra for solving equations involving energy and voltage
  • Study the principles of electric fields and forces on charged particles
  • Learn about the conservation of energy in electric systems
  • Explore the concept of electric potential difference and its implications
  • Investigate the behavior of positive vs. negative charges in electric fields
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of charged particles in electric fields, particularly in the context of energy transformations and electric potential.
Kuzon
A moving particle encounters an external electric field that decreases its kinetic energy from 9480 eV to 8260 eV as the particle moves from position A to position B. The electric potential atA is -43.0 V, and that at B is +25.0 V. Determine the charge of the particle. Include the algebraic sign (+ or -) with your answer
deltaE = q*deltaV
I got the solution correct using that formula, I was just wondering why the solution is positive? I thought NEGATIVE charge should flow from low (-43.0 V) to high (+25.0 V) voltage.
Also, does anyone know any good resources to learn the rules of electricity e.g. electrons flow from negative to positive
Yes, you are right. In normal conditions, negative charge should flow from low to high voltage. In that case the charge would gain kinetic energy at the expense of potential energy.
But if we force a positive charge to go from negative voltage to positive voltage, it will go as desired by losing its kinetic energy. Look at the problem statement, that is exactly the case. Kinetic energy of the charge particle has decreased. So, it should be positive charge which has moved.
So it's not the normal case as you think. I hope it helped.
Oh wow okay thanks man!
The key is that the field determines the direction of the force on the charge rather than the direction of motion itself. The force will cause an acceleration and that may eventually change the direction of motion but it depends on the initial conditions. It's a bit like throwing a ball upwards while gravity acts downwards.
