Stuck at proving a bounded above Subsequence
8 replies · 3K views
CGandC
Summary:: x
Let ## \{ a_{n} \} ## be a sequence.
Prove: If for all ## N \in { \bf{N} } ## there exists ## n> N ## such that ## a_{n} \leq L ## , then there exists a subsequence ## \{ a_{n_{k}} \} ## such that ##
a_{n_{k}} \leq L ##
My attempt:
Suppose that for all ## N \in {\bf{N}} ## there exists ## n> N ##, such that ## a_{n} \leq L ##. Since ## \{ a_{n} \} ## is a sequence, there exists a subsequence ## \{ a_{n_{k}} \}## such that there exists a monotonically increasing sequence of natural numbers ## \{ n_{k} \} ## such that ## \forall k \in {\bf{N}}, n_{k} \geq k ## . Let ## k \in {\bf{N}} ## be arbitrary so there exists ## n_{k} \geq k ##. Thus ( by universal instantiation of ## n_{k} ## in the statement " for all ## N \in {\bf{N}} ## there ... " ) there exists ## n > n_{k} > k ## such that ## a_{n} \leq L ##
However ,I don't know if ## a_{n_{k}} ## is less than or greater than ## a_{n} ## . So I'm stuck, how am I supposed to proceed from here to show that ## a_{n_{k}} \leq L ## ?
That is correct but you are not finding the right sequence here.
Why would that matter?
You can't because it won't be true for any n_k you come up with. You need to define n_k based on the sequence a. The best approach is to do this one element at a time. Let's say a_1, a_6, a_245 are three elements smaller than L. Can you find a fourth one? Once you have that, can you find a fifth one? Generalize and you get a full sequence.
Maybe the formal generalization goes as follows :
Let there be arbitrary ## N' \in { \bf{N} } ##, so there exists ## n > N' ## such that ## a_{n} \leq L ##.
We'll choose ## k' \in { \bf{N} } ## so that there exists ## n_{k'} \in { \bf{N} } ## ( " there exists ## n_{k'} \in { \bf{N} } ## " because since ## k' ## is a specific value and not arbitrary, then ## n_{k'} ## is also a specific value and not arbitrary ) such that ## n_{k'} = n ##. So it immediately follows that ## a_{n} = a_{n_{k'}} \leq L ##
Is this right?
You spend a lot of , big words justifying the existence of ##n_{k'}## that both doesn't seem necessary to me and sounds very confusing.I would just say something like, given ##n_1,...,n_k## in the subsequence, we know there is some ##n>n_k## such that ##a_n<L##. Let ##n_{k+1}=n##. And do this repeatedly to form the sequence.
So I can say the following?:
We know there is some ## n>n_k ## such that ## a_n < L ## . Let ## n_{k+1} = n ## .
We know there is some ## n>n_{k+1} ## such that ## a_n < L ## . Let ## n_{k+2} = n ## .
We know there is some ## n>n_{k+2} ## such that ## a_n < L ## . Let ## n_{k+3} = n ## .
So that the new subsequence we form is ## ( a_{n_k+1} , a_{n_{k+2}} , a_{n_{k+3}} , ... ) ## ?
The point of what I wrote is that I assumed we already had the first k elements of the sequence which you dropped from your final list, but your sequence also works. I would consider what you wrote a proof.
It's possible if you're taking a class they will require you to write something more formal, but
1.) Most of the mathematical community doesn't actually speak this way talking about universal instantiation etc.
2.) I think it's mostly a blocker to understanding the important point.
If you think what you wrote is not acceptable for a person grading this and you're not sure how to turn it into something acceptable we can discuss it.
I think my difficulty comes from trying to apply the definition of a subsequence ( from the book Introduction to Real Analysis . Robert G. Bartle , Donald R. Sherbert ):
Does this definition tell me:
1. If I have a sequence ## ( x_n ) ## and an increasing sequence of natural numbers ## ( n_k ) ## , then there exists a new sequence ## X' = ( x_{n_{k}} ) = ( x_{n_{1}} , x_{n_{2}}, ... , x_{n_{k}} , ... ) ##
Or
2. for all sequence ## ( x_n ) ## and for all increasing sequence of natural numbers ## ( n_k ) ## , then there exists a new sequence ## X' = ( x_{n_{k}} ) = ( x_{n_{1}} , x_{n_{2}}, ... , x_{n_{k}} , ... ) ##
Or
3. for all sequence ## ( x_n ) ## ,there exists an increasing sequence of natural numbers ## ( n_k ) ## , then there exists a new sequence ## X' = ( x_{n_{k}} ) = ( x_{n_{1}} , x_{n_{2}}, ... , x_{n_{k}} , ... ) ##
Which is correct ,and basically what is the logical format of the above definition?
I'm used to being able to use definitions and proven statements which start with quantifiers like " there exists " and " for all ". But in the above definition I have " Let ", so I feel like I don't exactly know how to use the definition ( not the first time I encountered such definition ).
1 and 2 are both correct.
X' depends on the sequence nk of course.
You are overthinking this.
Here is a sequence:
##x_1, x_2, x_3, x_4, x_5, x_6, ...##
Here is a subsequence I chose:
##x_2, x_4, x_8, x_{16}, ...##, here nk = 2,4,8,16,...
Here is another subsequence:
##x_1, x_3, x_5, x_7, ...##, here nk = 1,3,5,7,...
nk is just a list telling you which elements to use from the original sequence.
Basically your problem in the OP is to give a proper and possibly recursive definition of the sequence ##n_k## and then prove that ##n_k## is strictly increasing and also prove that ##a_{n_k}\leq L##. If you define properly the sequence ##n_k## then those two proofs will be immediate consequence of the proper definition.
