Stuck in a question about frictions
  • Thread starter Thread starter olesik
    Stuck
Journal friction refers to the friction that occurs in journal bearings, which support rotating shafts and allow for smooth movement. Bearing pressure is the load per unit area that acts on the surface of a bearing, influencing its performance and wear. Sliding friction occurs when two surfaces move against each other, and lubrication can reduce this friction. Rolling friction, on the other hand, is the resistance encountered when an object rolls over a surface. Understanding these concepts is essential for mechanical engineering applications.
olesik
Hello everybody,
I am doing ICS Btec Mech Eng course at the moment and I've stuck in a question about frictions.
So I have to explain journal friction, bearing pressure, sliding friction and rolling friction in relation to friction.
I've found following:
Sliding friction appears between two objects when they start moving against to each other. We can reduce friction between these object if apply some lubrication (usually we use oil)
The force resisting the motion when a body rolls on a surface is called the rolling resistance or rolling friction.
But what is a bearing preassure and journal friction? Does anybody can help with definitions please?
Thank you in advance.
A journal bearing is another name for a plain bearing.
