How Does the Wrecking Ball's Weight Affect the Boom's Stability?
  • Thread starter Thread starter smith5029
    Stuck
The discussion focuses on calculating the tension force in the support cable of a wrecking ball system, where the wrecking ball weighs 5400 N and the boom weighs 3800 N. The angles involved are 32° for the support cable and 48° for the boom. The initial attempt to derive the equation for torque was flawed due to incorrect application of the moment arm and confusion over the variable "L," which represents the length of the boom. The correct approach requires identifying the horizontal distances for torque calculations and ensuring that the forces are properly represented in the equations.
  • Understanding of torque and moment arms in physics
  • Knowledge of trigonometric functions, specifically sine and cosine
  • Familiarity with force equilibrium in static systems
  • Basic principles of mechanics related to levers and pivots
  • Study the principles of torque and how to calculate it using moment arms
  • Learn about static equilibrium and how to apply it to mechanical systems
  • Explore trigonometric applications in physics, particularly in force resolution
  • Review examples of tension calculations in similar mechanical setups
Students of physics, mechanical engineers, and anyone involved in structural analysis or mechanical design will benefit from this discussion.
smith5029
A wrecking ball (weight = 5400 N) is supported by a boom, which may be assumed to be uniform and has a weight of 3800 N. As the drawing shows, a support cable runs from the top of the boom to the tractor. The angle between the support cable and the horizontal is 32°, and the angle between the boom and the horizontal is 48°.
what i have done which i guess is wrong is.
L*5400 - Lsin(32)Ft + 1/2Lsin(48)(3800)=0
and then i got rid of the L's
and got 5400 - sin(32)Ft + 1/2sin(48)3800=0
but this was wrong, if you could just explain to me how to do this it would really help a lot thanks.
you have posted only the background info, not the actual problem (whatever it is)! Also...I don't see where "L" is defined...so I have no idea what that is either.
it wants to know the force of the cables tension, the length isn't defined but we can get it out right?
Okay. So the problem is asking you to find the force due to tension in the support cable. When I said that L wasn't defined, I didn't mean that the problem didn't specify the length, I meant that you introduced the symbol "L" without stating what it was. In fact, it is still unclear what it is. Remember that we can't see the picture, so it's hard to figure out what's going on.
Your equation seems to be trying to sum the torques around the point where the boom is attached to the tractor. So your terms seem to be
L*5400 = the torque on the boom (around that point) due to the weight of the wrecking ball (so, I'm inferring that you meant that L is the length of the boom). I don't think this term is correct, because you want to multiply the force by the moment arm, or lever arm, which is the perpendicular distance from the point of application of the force to the pivot point. That is not just the distance along the lever. The force is downward, so this perp. distance is the horizontal distance.
L/2*sin(48)*3800 seems to be the torque on the boom due to its own weight. It is in the same direction as the torque above. It has an error too. We want the moment arm, or the horizontal distance in this case. Is that given by Lsin(48)?
L*sin(32)*Ft
Now this one is very confusing. It seems that you're trying to calculate the counter torque provided by the support cable, (ie the torque that must prevent the boom from actually falling). But if so...then why did you use L? Isn't L the length of the boom? It's the force in the cable we're talking about now. And even if you had used the right length, can you see again why sine is not correct?
9K
46K
