Study of SHM of an object attached to a vertical spring
  • Context: High School
  • Thread starter Thread starter pgirl1729
The discussion revolves around the study of simple harmonic motion (SHM) of an object attached to a vertical spring, particularly focusing on the application of the law of conservation of energy and the role of gravitational potential energy in the analysis of oscillations.
  • Some participants argue that at the bottommost point of oscillation, maximum elastic potential energy is present only if gravitational potential energy is assumed to be zero.
  • Others suggest that the simplification in textbooks may be to focus on relevant content, questioning the necessity of including gravitational potential energy in the analysis.
  • A participant points out that if gravitational potential energy is considered at the lowest point, then elastic potential energy cannot be zero at the center of oscillation, as the spring is under tension.
  • One participant clarifies that changes in potential energy are what matter, and the force of gravity can be considered irrelevant in certain contexts, particularly when analyzing motion from an equilibrium position.
  • Another participant provides a mathematical formulation of the equations of motion, indicating that while gravity appears to be ignored, it is actually accounted for in the equilibrium position and the analysis of displacements.
  • There is a suggestion that calling potential energy 'elastic' may be misleading, as the net potential energy at equilibrium includes both gravitational and elastic components.
Participants express differing views on the treatment of gravitational potential energy in the context of SHM. There is no consensus on whether it should be included in the analysis, and the discussion remains unresolved regarding the implications of these assumptions.
Limitations include the dependence on assumptions about potential energy reference points and the definitions of equilibrium positions. The discussion highlights the complexity of analyzing SHM when multiple forms of potential energy are involved.
pgirl1729
When applying the law of conservation of energy, to the bottom most point of the oscillation, there's only maximum elastic potential energy if we assume it to have 0 potential energy. At the center of oscillation, there's maximum kinetic energy and zero elastic potential energy. That's how my book say. Why don't you add the gravitational potential energy too?
I suspect the book is simplifying things so that you can focus only on the relevant content.
Okay. YOU can make this assumption about the gravitational potential energy, but is the same assertion made in your textbook?
If that assertion about the gravitational potential energy at the lowest point has been made, then the elastic potential energy is not zero at the center of oscillation. Because the spring is under tension. The spring is not relaxed because the object hanging from the spring is stretching the spring.
You can, and I'll explain why it's not necessary, but please first answer the question I asked above.
No
Okay, sorry. Neglect that bit I stated about assuming the gravitational potential energy is zero. It's not relevant. You can assume any value you want because only changes in potential energy matter.
There's a good explanation here for why the force of gravity cancels out when the object of mass ##m## is attached to the spring and stretches it to a new equilibrium height. And since the force of gravity is not relevant the potential energy associated with that force is also not relevant.
Constant forces , such as gravity in this case ,can be subtracted out of the equations of motion if displacements are measured from the position of equilibrium. Write the equation of motion with gravity included and displacements measured from an arbitrary point. Then write the static equation by setting x dot dot to zero. Subtract the static equation from the dynamic equation and constants such as gravity and unstretched length will be subtracted out.
Equation of motion is
mX dot dot =mg - k(X - X_u)
Equilibrium equation is
0=mg - k(X_eq - X_u)
subtracting
mX dot dot = - k(X - X_u)+ k(X_eq - X_u)
mX dot dot = - k(X - X_eq)
and because X_eq is a constant
m(X - X_eq) dot dot = - k(X - X_eq)
Defining x= X-X_eq gives
mx dot dot=-kx
which looks like gravity is ignored - but gravity has not been ignored
Calling the PE 'elastic' was misleading (if indeed this was the wording of the book). The equilibrium position is where the net potential energy is zero - which includes both gravitational and elastic. Potential Energy is always relative and, of course, the elastic energy is not zero at equilibrium because the spring is partially stretched there. So they choose the equilibrium position for calculations because it' convenient.
  • · Replies 54 ·
  • · Replies 29 ·
