Note that you can use the same c1, c2, and c3 for both parts.
  • Thread starter Thread starter RedXIII
    Subspace
To determine if S is a subspace of R^n, it is essential to verify if it meets the criteria of closure under addition and scalar multiplication. In the case of n=4, the vector in S only spans a plane, thus failing to qualify as a subspace. For n=3, while a sphere is a 3-dimensional object, it does not satisfy subspace conditions since adding vectors can result in points outside the sphere. To show that the vectors 2v1 + 4v2, v2 + 2v3, and 5v3 form a basis for S in R^10, one must demonstrate their linear independence and that they span S. Understanding the definition of a subspace is crucial for solving these problems effectively.
RedXIII
1) Is S a subspace of R^n?
1.1) Given n=4 and a vector is in S if it is in the span of e1, e2 or in the span of e3, e4 where e1...e4 is the canonical basis of R^4
1.2) Given n=3 and S is a sphere of radius 1.
2) Let S be a subspace of R^10 with basis v1; v2; v3. Show that the vectors 2v1 + 4v2; v2 + 2v3; 5v3 also form a basis of S.
1.1) No, because if the vector only spans e1, e2 or e3, e4, then it would only generate a plane in R^4?
1.2) I was thinking yes because a sphere is a 3-d object, thus would be a subspace of itself in R^3. However, if the radius is one then would that be false because if I were to add the vectors of the sphere, it would be outside the sphere?
2) From what I read, I think I would have to prove that they are linear independent then prove that they can generate R^10 (both of which are already proven if v1,v2,v3 is the basis of R^10) but how would I show it without any actual numbers?
Thanks!
Anybody?
What's the definition of a subspace? For problem 1, you want to show that those cases either satisfy or don't satisfy the definition, so if you don't know the definition, that's the first thing you need to look up.
For problem 2, you need to be bit more careful. The problem doesn't say v1, v2, and v3 form a basis for R10. It says they form a basis for S, a subspace of R10. Now you're given three vectors — let's call them w1, w2, and w3 — and you want to show they form a basis for S. You need to show two things:
  1. w1, w2, and w3 span S. That is, if x is in S, then you can find constants c1, c2, and c3 such that x=c1w1+c2w2+c3w3.
  2. w1, w2, and w3 are linearly independent. That is, if c1w1+c2w2+c3w3=0, then c1=c2=c3=0 is the only solution.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
12K
