Does V Qualify as a Subspace of ℝ3?
The discussion confirms that the set V = {(a, b, c) ∈ ℝ³ | a² + b² = c²} qualifies as a subspace of ℝ³. It meets the criteria of being non-empty, closed under vector addition, and closed under scalar multiplication. The zero vector (0, 0, 0) is included in V, validating its status as a subspace. The dimension of V is determined to be three, as it exists within the three-dimensional space of ℝ³.
  • Understanding of vector spaces and their properties
  • Familiarity with the concept of subspaces in linear algebra
  • Knowledge of the Pythagorean theorem and its implications in geometry
  • Basic proficiency in operations involving real numbers
  • Study the properties of vector spaces in linear algebra
  • Learn about the criteria for subspaces and how to verify them
  • Explore examples of other subspaces in ℝ³
  • Investigate the implications of dimensionality in vector spaces
Students of linear algebra, mathematicians, and educators seeking to deepen their understanding of vector spaces and subspaces in three-dimensional geometry.
SYoungblood
Let X=ℝ3 and let V={(a,b,c) such that a2+b2=c2}. Is V a subspace of X? If so, what dimensions?
A vector space V exists over a field F if V is an abelian group under addition, and if for each a ∈ F and v ∈ V, there is an element av ∈ V such that all of the following conditions apply for all a,b ∈F and all u,v ∈V -- a(u + v) = au + av, (a + b)v = av + bv, a(bv)= (ab)v, and 1 × v = v.
a2+b2=c2 is abelian under addition because real numbers are commutative under that operation. I believe we would not have to concern ourselves with multiplication because we are not multiplying, and we would not have to concern ourselves with associativity under multiplication for the same reason. If we multiply this my the multiplicative identity, we get 1 × (a2+b2=c2)=a2+b2=c2. So, we are good for a vector space.
V is a subspace of X because it is nonempty, and closed under linear operations -- our friend Pythagoras showed that is true several millennia ago. Addition and multiplication are closed under ℝ, so we are good to go. Also, it passes through the origin, 0^2 + 0^2 = 0^2, obviously enough. Therefore, I have is as a subspace existing in three dimensions.
Thank you all for your time,
SY
This doesn't make any sense. The elements of V are vectors in ##\mathbb{R}^3## of the form <x, y, z> such that ##x^2 + y^2 = z^2##. x, y, and z are all real numbers, it's true.
Since the underlying space is ##\mathbb{R}^3##, addition is the usual vector addition, and scalar multiplication is the usual scalar multiplication.
Since V is a subset of ##\mathbb{R}^3## you don't have to verify all of the axioms for a vector space. What you do need to verify is that for vectors in set V,
  • The 0 vector is an element of V
  • V is closed under vector addtion. I.e., if ##u \in V## and ##w \in V## is ##u + w \in V##?
  • V is closed under scalar multiplication. I.el, if ##u \in V## and c is a scalar (a real) is ##cv \in V##?
No, that's not how it works. See above.
SY
I got it, this and breaking out my old LA text helped. Thank you.
SY
